How to create a excel file using ilogic? Thanks
11 REPLIES 11
Message 1 of 12
MtigaM
8751 Views, 11 Replies
11 REPLIES 11
Message 2 of 12
Curtis_Waguespack
in reply to: MtigaM
Hi MtigaM,
Here is an iLogic example.
I hope this helps.
Curtis
'define the file to create/open
myXLS_File = "C:\Temp\Best_Excel_File_Ever.xls"
‘get the Inventor user name from the Inventor Options
myName= ThisApplication.GeneralOptions.UserName
'define Excel Application object
excelApp = CreateObject("Excel.Application")
'set Excel to run visibly, change to false if you want to run it invisibly
excelApp.Visible = True
'suppress prompts (such as the compatibility checker)
excelApp.DisplayAlerts = false
'check for existing file
If Dir(myXLS_File) <> "" Then
'workbook exists, open it
excelWorkbook = excelApp.Workbooks.Open(myXLS_File)
ExcelSheet = ExcelWorkbook.Worksheets(1)
Else
'workbook does NOT exist, so create a new one
excelWorkbook = excelApp.Workbooks.Add
End if
'Insert data into Excel.
With excelApp
    .Range("A1").Select
    .ActiveCell.FormulaR1C1 = "Hello, " & myName
End With
'set all of the columns to autofit
excelApp.Columns.AutoFit
'save the file
excelWorkbook.SaveAs (myXLS_File)
''close the workbook and the Excel Application
''uncomment if you want to close the xls file at the end
'excelWorkbook.Close
'excelApp.Quit
'excelApp = Nothing
Message 3 of 12
MtigaM
in reply to: Curtis_Waguespack
Thanks alot, this is what i am looking for!
Message 4 of 12
MtigaM
in reply to: MtigaM
Is it possible to open a template excel file somewhere and then save it as a new excel in another place?
Message 5 of 12
Curtis_Waguespack
in reply to: MtigaM
Hi MtigaM,
To specify the template to use you can use this example.
I hope this helps.
Curtis
Else
'create a new spreadsheet from template
excelWorkbook = excelApp.Workbooks.Add (Template: = "C:\Temp\Best_Excel_Template_Ever.xlt")
End if
With excelApp
	.Range("A1").Select
End With
'save the file
'excelApp.Quit
'excelApp = Nothing
Message 6 of 12
MtigaM
Thank you very much!
Message 7 of 12
can we specify the directory of the saved file?
Message 8 of 12
Thank you very much. This is brilliant. Could we create different sheets as well
Message 9 of 12
scottvan
in reply to: hidayethkosal
I have been using the following code to check if I have the proper amount of worksheets, and add worksheets if necessary:
'Define Excel application and run in the background
xlApp = CreateObject("Excel.Application")
xlApp.Visible = False
xlApp.DisplayAlerts = False
xlWorkbook = xlApp.Workbooks.Add
xlWorksheets = xlWorkbook.Sheets
'Check number of sheets, add if necessary
Do While xlApp.Workbooks(1).Sheets.Count < 3
	xlApp.Workbooks(1).Sheets.Add
Loop
'Name Excel Sheets
xlApp.Workbooks(1).Sheets(1).Name = "First Sheet Name"
xlApp.Workbooks(1).Sheets(2).Name = "Second Sheet Name"
xlApp.Workbooks(1).Sheets(3).Name = "Third Sheet Name"
Hope this helps!
Message 10 of 12
JOJO.S
If the last line of code below is commented, after running the rule it open another read-only excel file. Is it possible to update the excel without closing and opening it again?
'excelApp.Quit
'excelApp = Nothing
Message 11 of 12
leoow96
in reply to: MtigaM
Hello 🙂
How can I save the Excel file with the Windows form?
For example, how do I write in sheet 2?
Message 12 of 12
tableauzeichner1
Hey, for example like this, you can specify the directory and get a variable name for your file. 😉
