Hi MtigaM,
Here is an iLogic example.
I hope this helps.
Curtis
'define the file to create/open
myXLS_File = "C:\Temp\Best_Excel_File_Ever.xls"
‘get the Inventor user name from the Inventor Options
myName= ThisApplication.GeneralOptions.UserName
'define Excel Application object
excelApp = CreateObject("Excel.Application")
'set Excel to run visibly, change to false if you want to run it invisibly
excelApp.Visible = True
'suppress prompts (such as the compatibility checker)
excelApp.DisplayAlerts = false
'check for existing file
If Dir(myXLS_File) <> "" Then
'workbook exists, open it
excelWorkbook = excelApp.Workbooks.Open(myXLS_File)
ExcelSheet = ExcelWorkbook.Worksheets(1)
Else
'workbook does NOT exist, so create a new one
excelWorkbook = excelApp.Workbooks.Add
End if
'Insert data into Excel.
With excelApp
.Range("A1").Select
.ActiveCell.FormulaR1C1 = "Hello, " & myName
End With
'set all of the columns to autofit
excelApp.Columns.AutoFit
'save the file
excelWorkbook.SaveAs (myXLS_File)
''close the workbook and the Excel Application
''uncomment if you want to close the xls file at the end
'excelWorkbook.Close
'excelApp.Quit
'excelApp = Nothing
Hi MtigaM,
To specify the template to use you can use this example.
I hope this helps.
Curtis
'define the file to create/open myXLS_File = "C:\Temp\Best_Excel_File_Ever.xls" ‘get the Inventor user name from the Inventor Options myName= ThisApplication.GeneralOptions.UserName 'define Excel Application object excelApp = CreateObject("Excel.Application") 'set Excel to run visibly, change to false if you want to run it invisibly excelApp.Visible = True 'suppress prompts (such as the compatibility checker) excelApp.DisplayAlerts = false 'check for existing file If Dir(myXLS_File) <> "" Then 'workbook exists, open it excelWorkbook = excelApp.Workbooks.Open(myXLS_File) ExcelSheet = ExcelWorkbook.Worksheets(1) Else 'create a new spreadsheet from template excelWorkbook = excelApp.Workbooks.Add (Template: = "C:\Temp\Best_Excel_Template_Ever.xlt") End if 'Insert data into Excel. With excelApp .Range("A1").Select .ActiveCell.FormulaR1C1 = "Hello, " & myName End With 'set all of the columns to autofit excelApp.Columns.AutoFit 'save the file excelWorkbook.SaveAs (myXLS_File) ''close the workbook and the Excel Application ''uncomment if you want to close the xls file at the end 'excelWorkbook.Close 'excelApp.Quit 'excelApp = Nothing
Thank you very much. This is brilliant. Could we create different sheets as well
I have been using the following code to check if I have the proper amount of worksheets, and add worksheets if necessary:
'Define Excel application and run in the background xlApp = CreateObject("Excel.Application") xlApp.Visible = False xlApp.DisplayAlerts = False xlWorkbook = xlApp.Workbooks.Add xlWorksheets = xlWorkbook.Sheets 'Check number of sheets, add if necessary Do While xlApp.Workbooks(1).Sheets.Count < 3 xlApp.Workbooks(1).Sheets.Add Loop 'Name Excel Sheets xlApp.Workbooks(1).Sheets(1).Name = "First Sheet Name" xlApp.Workbooks(1).Sheets(2).Name = "Second Sheet Name" xlApp.Workbooks(1).Sheets(3).Name = "Third Sheet Name"
Hope this helps!
If the last line of code below is commented, after running the rule it open another read-only excel file. Is it possible to update the excel without closing and opening it again?
'excelApp.Quit
'excelApp = Nothing
Hey, for example like this, you can specify the directory and get a variable name for your file. 😉
