Solved by Curtis_Waguespack. Go to Solution.
Hi MtigaM,
Here's an example.
I hope this helps.
Curtis
Dim IPJ as String Dim IPJ_Name as String Dim IPJ_Path as String Dim FNamePos As Long 'set a reference to the FileLocations object. IPJ = ThisApplication.FileLocations.FileLocationsFile 'get the location of the last backslash seperator FNamePos = InStrRev(ThisApplication.FileLocations.FileLocationsFile, "\", -1) 'get the project file name with the file extension IPJ_Name = Right(IPJ, Len(IPJ) - FNamePos) 'get the project name (without extension) IPJ_ShortName = Left(IPJ_Name, Len(IPJ_Name) - 4) 'get the path of the folder containing the project file IPJ_Folder_Location = Left(ThisApplication.FileLocations.FileLocationsFile, Len(IPJ) - Len(IPJ_Name)) MessageBox.Show("Project Name: " & IPJ_ShortName _ & vblf & "Project File Name: " & IPJ_Name _ & vblf & "Project Path: " & IPJ_Folder_Location _ & vblf & "Project Path and File Name: " & ThisApplication.FileLocations.FileLocationsFile _ , "iLogic")
one more question:
Is it possible to export the parts list to an excel template with ilogic? : )
Thanks again!
Hi MtigaM,
Have a look at these links:
Includes exporting parts list to Excel:
http://inventortrenches.blogspot.com/2011/02/ilogic-code-for-parts-lists-title.html
Focuses on exporting parts list to an Excel template:
http://inventortrenches.blogspot.com/2011/06/ilogic-export-parts-list-with-options.html
I hope this helps.
Curtis
Hi Curtis_Waguespack,
Im using Inventor 2010, and the parts list has to be exported as xls file, but my excel is 2007(xlsx).
Is later version of Inventor able to export parts list to xlsx files?
Thank you!
Hi MtigaM,
I don't think your version of Inventor can write out to an *.xlsx file. But you can use an *.xls file with Excel 2007 (it can read or write both). Just open your *.xlsx file and save it as a *.xls and you should be set.
I hope this helps.
Curtis
