Inventor Programming - iLogic, Macros, AddIns & Apprentice
Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
How to Change Parameters using ApprenticeServer
2 REPLIES 2
386 Views, 2 Replies
I have changing the parameters of an inventor document using the inventor API by create an instanc e of inventor and open the document,but it  take more time .is it possible to use ApprenticeServer to change the parameters of the document.????
My code is
Dim oPartDoc As PartDocument = inventorApp.ActiveDocument
        Dim oParameters As Parameters
        oParameters = oPartDoc.ComponentDefinition.Parameters()
        Dim oLengthParam, oWidthParam, oHeightParam As Parameter
        oLengthParam = oParameters.Item("d0")
        oWidthParam = oParameters.Item("d1")
        oHeightParam = oParameters.Item("d2")
        oLengthParam.Expression = TextBox1.Text
        oWidthParam.Expression = TextBox2.Text
        oHeightParam.Expression = TextBox3.Text
        oPartDoc.Update()
 how can achive the same method using ApprenticeServer? anyone help?
Tags (1)
2 REPLIES 2
ekinsb
It's not possible to edit parameter values, or even query parameters, using Apprentice.  Apprentice provides a small subset of the Ivnentor API functionality.  You'll need to use Inventor.
Brian Ekins
Inventor and Fusion 360 API Expert
Mod the Machine blog
Okey ..Thanks Smiley Happy
