Is it possible to make iLogic rule to do this:
In dwg Place part and in Browser to see part name without extra typing. Not Sheet 1 sheet 2 etc.
That would be huge help.
Thank you
Solved by GosponZ. Go to Solution.
Solved by jdkriek. Go to Solution.
Jonathan,
when i try first time it work perfect. Now i'm trying and every time in new sheet giving me same name
Thank you
Ah multiple sheets with diffrent parts? Try this.
oDoc = ThisDoc.Document oSheets = oDoc.Sheets For Each oSheet In oSheets oSheet.activate oView = oSheet.DrawingViews.Item(1) modelName = oView.ReferencedDocumentDescriptor.ReferencedDocument oProp = modelName.PropertySets.Item("Design Tracking Properties") ActiveSheet.Sheet.Name = oProp.Item("Part Number").Value Next oSheets(1).activate
I copy paste straight from web and that is not good idea. I place code into word and then i copy paste into rule and is working like charm. Thanks a lot
