I have an excel spreadsheet I need to access. It is embedded within a dwg file(I'm a C# guy, not Inventor). How can I access this spreadsheet from an addon written in C#? I wasn't sure where to look in the documentation.
I assume I should start with ActiveDocument, but from there I'm not sure where to go. I'll need to be able to read and write to the table.
I don't think it is an Excel document anymore as it should be now inserted as a custom table. To access this table you can do it like the following.
Inventor.DrawingDocument oDrawDoc = ThisApplication.ActiveDocument; Sheet oSheet = oDrawDoc.ActiveSheet; if (oSheet.CustomTables.Count > 0) { CustomTable oCustomTable = oSheet.CustomTables.Item(1); foreach (Row oRow in oCustomTable.Rows) { string[] RowArray = new string[oCustomTable.Columns.Count + 1]; for (int I = 1; I <= oCustomTable.Columns.Count; I++) { RowArray[I] = oRow.Item(I).Value; } Interaction.MsgBox(string.Join(Constants.vbLf, RowArray)); } }
No, what I mean is I actually have it embedded as an Excel spreadsheet(not a custom table). It's listed under the 3rd party tab. When I open it from inside inventor, it opens the spreadsheet in Excel.
Here is the code which DOES work in VBA
Sub openexcel() Dim oApp As Inventor.Application Set oApp = ThisApplication Dim oOleRef As ReferencedOLEFileDescriptor Set oOleRef = oApp.ActiveDocument.ReferencedOLEFileDescriptors.Item(1) Dim oWB As Excel.Workbook Call oOleRef.Activate(kEditOpenOLEVerb, oWB) Dim oSheet As Excel.WorkSheet Set oSheet = oWB.ActiveSheet End Sub
Here is what I have so far in C#, but it crashes on kEditOpenOLEVerb
Inventor.Application oApp = this.m_inventorApplication; ReferencedOLEFileDescriptor oOleRef = oApp.ActiveDocument.ReferencedOLEFileDescriptors[1]; Microsoft.Office.Interop.Excel.Workbook oWB; oOleRef.Activate(kEditOpenOLEVerb, oWB); Microsoft.Office.Interop.Excel._Worksheet oSheet = (Microsoft.Office.Interop.Excel._Worksheet)oWB.ActiveSheet;
Any idea how I can modify this C# code to work the same way the VBA does? (I have to use C#)
I converted what you had in VBA to VB.NET and then to C# and it looks like this. I have changed it so I could test it from a standalone exe with the first line.
public void openexcel() { Inventor.Application oApp = System.Runtime.InteropServices.Marshal.GetActiveObject("Inventor.Application"); ReferencedOLEFileDescriptor oOleRef = oApp.ActiveDocument.ReferencedOLEFileDescriptors.Item(1); Excel.Workbook oWB = null; oOleRef.Activate(OLEVerbEnum.kEditOpenOLEVerb, oWB); Excel.WorkSheet oSheet = oWB.ActiveSheet; }
I don't do much C# ..
Your code converted to C# is very similar to what I have for C#. However, unless you have a using reference I don't have yours wouldn't work either. This is because in VBA, Inventor has kEditOpenOLEVerb defined as something. But from outside Inventor, C# or VB code still needs to define kEditOpenOLEVerb before it can be used.
Look at it agin, kEditOpenOLEVerb is not correct in yours I dont think.. it should be OLEVerbEnum.kEditOpenOLEVerb...
I tried that as well. Neither way works for me. As I have it now, it tells me it doesn't exist in the current contect(which makes sense). Using your way, OLEVerbEnum.kEditOpenOLEVerb, it tells me that "the best overloaded method match has some invalid arguments".
I don't know the answer to the C# part, but I tried what I have in VB.NET and it works just fine.. This is what I have in VB.NET..
Sub openexcel() Dim oApp As Inventor.Application = System.Runtime.InteropServices.Marshal.GetActiveObject("Inventor.Application") Dim oOleRef As ReferencedOLEFileDescriptor = oApp.ActiveDocument.ReferencedOLEFileDescriptors.Item(1) Dim oWB As Excel.Workbook = Nothing oOleRef.Activate(OLEVerbEnum.kEditOpenOLEVerb, oWB) Dim oSheet As Excel.Worksheet = oWB.ActiveSheet MsgBox(oSheet.Name) End Sub
Here is the error I'm coming across: "cannot convert from 'Microsoft.Office.Interop.Excel.Workbook' to out object". My code below.
Inventor.Application oApp = this.m_inventorApplication; ReferencedOLEFileDescriptor oOleRef = oApp.ActiveDocument.ReferencedOLEFileDescriptors[1]; Microsoft.Office.Interop.Excel.Workbook oWB = null; oOleRef.Activate(OLEVerbEnum.kEditOpenOLEVerb, oWB); Microsoft.Office.Interop.Excel.Worksheet oSheet = (Microsoft.Office.Interop.Excel.Worksheet)oWB.ActiveSheet; string name = oSheet.Name;
The Activate function needs an out object. However, it must also be an Excel object, and C# seems unable to figure this out on its own. Can anyone give advice on this?
That means you should add "out" before the second parameter. I slightly modied the code and it should work: (also recommend to use try-catch as more as you can if you are not sure of how to use those functions)
using Inventor;
using System.Runtime;
using Microsoft.Office.Interop.Excel;
Inventor.Application oApp = null;
try
oApp = System.Runtime.InteropServices.Marshal.GetActiveObject("Inventor.Application") as Inventor.Application;
catch
if (oApp == null) return;
if (oApp.ActiveDocument != null) {
if (oApp.ActiveDocument.ReferencedOLEFileDescriptors.Count > 0)
Object retObj = null;
oOleRef.Activate(OLEVerbEnum.kEditOpenOLEVerb, out retObj);
try
Workbook oWB = (Workbook)retObj;
Worksheet oSheet = (Worksheet)oWB.ActiveSheet;
oWB.Close();
catch(Exception ex)
MessageBox.Show(ex.ToString());
