Inventor Programming - iLogic, Macros, AddIns & Apprentice
Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
How can I find valid color style names for use in iLogic rules
2 REPLIES 2
AutoDsteinV
737 Views, 2 Replies
I will appreciate any help with this question.
The following code returns a list of the render style names in Inventor 2014 :
Dim colorList As New ArrayList
For Each style As RenderStyle In ThisDoc.Document.RenderStyles
colorList.Add(Style.Name)
Next
MultiValue.List("primary_color") = colorList
iProperties.Value("Summary", "Comments") = _
ThisApplication.ActiveDocument.ActiveRenderStyle.Name
The code returns a list of  render style names:
Gold-Metal
Gunmetal-Polished
Titanium-Polished
Steel Blue
Silver
and more . . .
If I use these names in an iLogic rule to set the part color:
iProperties.PartColor="Gold-Metal"
I get an error (system argument exception).
The correct argument is:
iProperties.PartColor="Gold Metallic"
The following render style names also return an exception:
iProperties.PartColor="Gunmetal-Polished"
iProperties.PartColor="Titanium-Polished"
The correct arguments are:
iProperties.PartColor="Gunmetal (New/Polished)"
iProperties.PartColor="Metal-Titanium (Polished)"
Where/how can I get a list of correct color style names to use in iLogic rules in Inventor 2014 ?
Thank you for considering my request.
2 REPLIES 2
Could you please test iLogic rules in the attached part model.  They works for me.
This rule populates multi-value parameter with the styles names:
MultiValue.SetValueOptions(True, DefaultIndex := 0)
Next
Beep
MsgBox("Done")
This rule changes active style:
iProperties.PartColor =  primary_color
ThisDoc.Document.ActiveRenderStyle.Name
 cheers,
Vladimir Ananyev
Developer Technical Services
Autodesk Developer Network
Vladimir Ananyev,
I was in Paris/France when you posted the code that solves the problem, and did not have access to my HP Z1 workstation to test your code.
I have now tested your code and it works.
The line “iProperties.PartColor = primary_color” in “This rule changes active style:” does the trick.
I can now use the color style names in the list “primary_color” to set the part color . . . with no errors.
I really appreciate your help.
AutoDsteinV
