I am trying to deterimne if a hole feature sketch point is on the planar face. When I run this with a sketch that is not consumed by a Hole feature all returns correct. when I consume the same sketch with a hole feature it does not work correctly. Can anyone instruct me on why or what is incorrect below?
Public Sub CheckHolePoint()
Dim oPartDoc As PartDocument
Set oPartDoc = ThisApplication.ActiveDocument
' Set a reference to the component definition.
Dim oDef As PartComponentDefinition
Set oDef = oPartDoc.ComponentDefinition
Dim oSketch As PlanarSketch
For Each oSketch In oPartDoc.ComponentDefinition.Sketches
If TypeOf oSketch.PlanarEntity Is Face And (oSketch.Adaptive) Then
Dim oFacePlane As Face
Set oFacePlane = oSketch.PlanarEntity
Dim oSKPoint As SketchPoint
Dim oPoint As Point
For Each oSKPoint In oSketch.SketchPoints
Dim oSE As SurfaceEvaluator
Set oSE = oFacePlane.Evaluator
Dim oCords(1) As Double
oCords(0) = oSKPoint.Geometry.X
oCords(1) = oSKPoint.Geometry.Y
Debug.Print "IsParam: " & oSE.IsParamOnFace(oCords)
Next
End If
Next
End Sub
HI,
I am able to recreate this behavior. I believe it is because the coordinates of the SketchPoint for a hole are in the middle of the hole once it is consumed and is not on the surface. You can test this by moving the coordinate tested with IsParamOnFace() so that it is not where the hole is. In my tests with my simple part I changed your code (oCords(0) = oSKPoint.Geometry.X + 0.5) and IsParamOnFace was then True.
I am not sure what your actual requirement is. There should be other ways to find out you need to know using some other approach. This VBA help example could be of interest: IsCylindricalFaceInterior(). Help on my system is here:
"C:\Program Files\Autodesk\Inventor 2014\Local Help\admapi_18_0.chm"
Wayne
Wayne,
Thank you for the information, I have tested and am getting some True and some False based on the value I add to to the "X" point. Is the value relative to a given parameter (i.e. perpendicaluar to the centerline axis ). I am trying to determine if sketch points consumed by Adaptive Hole Features are located on the face that the sketch was modeled on. If they are not then move them back to the nearest edge.
Would another method be better?
Nathaniel
Hi Nathaniel,
I am not sure I understand this. Are moving sketch points the only way to achieve your requirement?
Can you provide a part or assembly that I could use to test? (you can use the case if you want to keep it private).
Maybe FindUsingRay or FindUsingVector would help find the edge.
Wayne
