Hi all,
I was wondering if someone knows how to change the color that the "Interference Analyze" tool identifies with??
I recently converted from 2010 to Inventor 2011 Pro. 2010 had a Dark Translucent Red which was extremely helpful. 2011 has a Light Translucent Red which is extremely difficult to make out ( I have a massive assembly). Identifying these fouls/interferences is vital to my job.
I tried Styles Editor, View Styles, Application/Document Settings, and even part manipulation! (bah!)
You have know Idea how much I would appreciate the help.
Please let me know if you have questions.
Thanks in advance!
OJ
HII-NNS
The following iLogic code from Curtis Waguespack is what I like to use
Sub Main Dim oAsmDoc As AssemblyDocument oAsmDoc = ThisApplication.ActiveDocument Dim oAsmCompDef As AssemblyComponentDefinition oAsmCompDef = oAsmDoc.ComponentDefinition ' Add each occurrence in the assembly to the object collection. Dim oCheckSet As ObjectCollection oCheckSet= ThisApplication.TransientObjects.CreateObjectCollection Dim oOcc As ComponentOccurrence For Each oOcc In oAsmCompDef.Occurrences oCheckSet.Add (oOcc) Next ' Call the AnalyzeInterference method, passing in a single ' collection. This will cause it to compare everything against ' everything else. Dim oResults As InterferenceResults oResults = oAsmCompDef.AnalyzeInterference(oCheckSet) ' Display the results of the interference. MessageBox.Show(oResults.Count & " Interferences found ","iLogic") Dim oResult As InterferenceResult Dim iCount As Integer iCount = 0 For Each oResult In oResults iCount = iCount + 1 Component.Color(FullOccurrenceName(oResult.OccurrenceOne)) = "Yellow" Component.Color(FullOccurrenceName(oResult.OccurrenceTwo)) = "Magenta" MessageBox.Show(" " & FullOccurrenceName(oResult.OccurrenceOne) & " (colored yellow)" _ & vbLf & "interferes with " _ & vbLf & " " & FullOccurrenceName(oResult.OccurrenceTwo) & " (colored magenta)" _ & vbLf & "" _ & vbLf & "Volume: " & Round(oResult.Volume,5) & " cm^3", _ " Interference "& iCount) Component.Color(FullOccurrenceName(oResult.OccurrenceOne)) = "As Material" Component.Color(FullOccurrenceName(oResult.OccurrenceTwo)) = "As Material" Next End Sub ' Used to display the full path of an occurrence. This is the path of the ' occurrence within the assembly structure. Private Function FullOccurrenceName(Occ As ComponentOccurrence) As String Dim i As Integer For i = 1 To Occ.OccurrencePath.Count FullOccurrenceName = Occ.OccurrencePath.Item(i).Name Next End Function
