Hi
Is there a api to read part number value in properties "Project Tab" for a drawing document??
Sheena
Solved by YuhanZhang. Go to Solution.
Yes, the it is a Property in PropertySet, please try below code:
Sub Sample() Dim oSet As PropertySet Set oSet = ThisApplication.ActiveDocument.PropertySets(3) Dim oProp As Property Set oProp = oSet.Item("Part Number") MsgBox oProp.Value End Sub
