We are using Inventor 2011 and I would like to make a small app that allows my users to graphically select one or more occurrences of a rectangular pattern feature Then allow them to suppress them if desired.
I have determined the code to loop through the pattern occurrences and toggle suppression for any instance.
What I do not know how to do is determine which occurrences have been graphically selected.
At this time I am only concerned with round hole features. (Perforated metal)
Any help here?
You may use SelectSet object to access all objects that are currently selected using the Select command. If object type is kFeaturePatternElementObject then you may treat it as pattern occurrence. Its property Index gives you element position in the pattern.
Private Sub RectPatterns() Dim oDoc As PartDocument Set oDoc = ThisApplication.ActiveDocument Dim oDef As PartComponentDefinition Set oDef = oDoc.ComponentDefinition Dim oRP As RectangularPatternFeature Set oRP = oDef.Features.RectangularPatternFeatures.Item(1) Dim oSSet As SelectSet Set oSSet = oDoc.SelectSet If oSSet.Count = 0 Then Exit Sub Dim Entity As Object Set Entity = oSSet.Item(1) If Entity.Type <> ObjectTypeEnum.kFeaturePatternElementObject Then Beep MsgBox "Select feature pattern element" Exit Sub End If Dim oFPE As FeaturePatternElement Set oFPE = Entity If oFPE.Index > 1 Then oFPE.Suppressed = Not oFPE.Suppressed Else Beep MsgBox "Cannot suppress the first feature pattern element" Exit Sub End If oDoc.Update End Sub
Hope this helps.
Cheers,
Vlad,
I think you misunderstand.
I do not want to select the pattern Feature Insances in the Browser Tree.
I am talking about selecting the Pattern instances in the graphics display.
Selected elements return Edge or Face when selected there..
I need to know how to get the pattern instance from the selected face or edge.
Trying to select the desired element from the browser tree is rediculously difficult as it is a 1D array.
This is also possible. In the case of hole pattern you may select cylindric faces or cirlce edge (if you do it in the part context). Function ElementIndexByFace returns the index of selected pattern element. 1 corresponds to the source hole.
Function ElementIndexByFace(ByVal oSelectedFace As Face) As Integer Dim oDef As PartComponentDefinition Set oDef = oSelectedFace.Parent.Parent If oSelectedFace.CreatedByFeature.Type _ = ObjectTypeEnum.kHoleFeatureObject Then ElementIndexByFace = 1 ElseIf oSelectedFace.CreatedByFeature.Type _ = ObjectTypeEnum.kRectangularPatternFeatureObject Then Dim oRP As RectangularPatternFeature Set oRP = oSelectedFace.CreatedByFeature Dim oFace As Face Dim i As Integer Dim oFPE As FeaturePatternElement For i = 2 To oRP.PatternElements.Count Set oFPE = oRP.PatternElements.Item(i) Set oFace = oFPE.Faces.Item(1) If oSelectedFace Is oFace Then ElementIndexByFace = i Exit Function End If Next Else ElementIndexByFace = -1 End If End Function 'ElementIndexByFace Private Sub PatternElementByFace() Dim oDoc As PartDocument Set oDoc = ThisApplication.ActiveDocument Dim SSET As SelectSet Set SSET = oDoc.SelectSet If SSET.Count = 0 Then Call MsgBox("Select cylindric face in pattern element") Exit Sub End If 'no error checking for brevity Dim oSelectedFace As Face Set oSelectedFace = SSET.Item(1) Dim Index As Integer Index = ElementIndexByFace(oSelectedFace) If Index > 0 Then Debug.Print "Element #" & Index Else MsgBox "Failed to find pattern element index." End If End Sub 'PatternElementByFace Private Sub PatternElementByEdge() 'no error checking for brevity Dim oDoc As PartDocument Set oDoc = ThisApplication.ActiveDocument Dim SSET As SelectSet Set SSET = oDoc.SelectSet If SSET.Count = 0 Then Call MsgBox("Select circle edge in pattern element") Exit Sub End If Dim oSelectedEdge As Edge Set oSelectedEdge = SSET.Item(1) 'verify GeometryType - should be circle curve If oSelectedEdge.GeometryType <> CurveTypeEnum.kCircleCurve Then Call MsgBox("Select circle edge in pattern element") Exit Sub End If Dim Index As Integer Index = 0 Dim oFace As Face For Each oFace In oSelectedEdge.Faces If oFace.SurfaceType = SurfaceTypeEnum.kCylinderSurface Then Index = ElementIndexByFace(oFace) End If Next If Index > 0 Then Debug.Print Index Else MsgBox "Failed to find pattern element index." End If End Sub 'PatternElementByEdge
In assembly context SelectSet returns corresponding proxy objects (FaceProxy, EdgeProxy, etc.). In this case you should use NativeObject property to get object in the context of definition (e.g., Part Document)..
Please fill free to modify this code to satisfy your particular requirements.
Hope this helps.
