Inventor Programming - iLogic, Macros, AddIns & Apprentice
Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
Get name of current assembly, when editing sub-assemblies
1 REPLY 1
pball
383 Views, 1 Reply
I have a script which currently references ThisApplication.ActiveDocument which is fine if you are in the top level assembly. But when I go into a sub-assembly to edit it, I would like the script to get the name of the sub-assembly.
So is there a simple way to get the name of the sub-assembly you are currently editing?
1 REPLY 1
AlbertoTorres
in reply to: pball
This scriptlet will give the name of the object you are currently editing.
1. - Checks if the current document is an assembly. If it is given a message and exits.
2. - Displays the name of the document currently being edited
A Sub-assembly o Part that is being edited) If you're not editing anything,
gives the name of the parent assembly.
** You should now catch the type of document being edited to make other functions on it, for example.
Public Sub DameNombre()
    If ThisApplication.ActiveDocumentType <> kAssemblyDocumentObject Then
        MsgBox ("Macro only for Assembly")
        End
    If ThisApplication.ActiveEditDocument.DocumentType = kAssemblyDocumentObject Then
        MsgBox ("Sub-Assembly name = " & ThisApplication.ActiveEditDocument.DisplayName)
    Else
        MsgBox ("Part name = " & ThisApplication.ActiveEditDocument.DisplayName)
End Sub
