Inventor Programming - iLogic, Macros, AddIns & Apprentice
Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
Get file names from folder?
6 REPLIES 6
769 Views, 6 Replies
I'm trying to get the filenames of some drawings in a folder.  I've got the following code, but it's not working.  I get a file count from the line "filecount = objFiles.Count", so it's recognizing "objFiles" as the collection of files in the folder, but everything after that simply does nothing.  Oddly, I can change the "If" statement from "<>" to "=", and it still reads the "Then" statement in both cases.  However, the FileName is blank.  What am I doing wrong?
Dim objFile As FileDialogs
    Set objFile = New FileDialogs
    objFile.Title = strFolderName
    objFile.StartInDir = "C:\Documents and Settings"
    strFolderName = objFile.ShowOpen
    strFolderName = Left$(strFolderName, InStrRev(strFolderName, "\") - 1)
MsgBox strFolderName
    Dim fso As Object
    Dim objFiles As Object
    Dim filecount As Integer
    Dim dwgfilenum As Integer
    Dim poo As Variant
     'Create objects to get a count of files in the directory
    Set fso = CreateObject("Scripting.FileSystemObject")
    On Error Resume Next
    Set objFiles = fso.GetFolder(strFolderName).Files
    'If Err.Number <> 0 Then
        For dwgfilenum = 1 To filecount
            If Right((objFiles.Item(dwgfilenum).FullFileName), 3) <> "dwg" Then
            poo = objFiles.Item(dwgfilenum).FullFileName
            MsgBox poo
            'filecount = filecount - 1
            End If
        Next
        MsgBox filecount
6 REPLIES 6
augusto.goncalves
I'm not sure this is a Inventor API question, or if you are facing this only inside Inventor VBA engine. ]
Anyway, I tried the following and it is working fine:
Public Sub test()
    Dim fso As New FileSystemObject
    Dim fol As Folder
    Set fol = fso.GetFolder("C:\")
    For Each oFile In fol.Files
        Debug.Print oFile.Name
    Next
End Sub
Can you try again with for each instead?
Augusto Goncalves
Twitter @augustomaia
Autodesk Developer Network
in reply to: augusto.goncalves
Probably should have noted that I'm using IV R2010... It recognizes "New FileSystemObject" and "Folder" as a user-defined types, which are not defined.  I'm an amateur ar VBA, and the user-defined type is above my level.  Thanks for the help, anyway.
augusto.goncalves
Those types are defined on the system, but you need to add reference to Microsoft Scripting, which will also help you debug your code.
Augusto Goncalves
How do I add the reference to MS Scripting?  If I need to get into the local drive, I'll have to contact I.T. department, not a problem but I'd like to know what to tell them I want done.  Thanx.
augusto.goncalves
Just go to Tool, references, and then select as shown below.
Augusto Goncalves
I added the MS scripting, but I was also able to get the information I needed with the code I had... I just used a "For Each" statement.  Yhanks a bunch for your help!
