Inventor Programming - iLogic, Macros, AddIns & Apprentice
Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
Get Inventor TreeView in VB.net Customised
4 REPLIES 4
amitnkukanur
1680 Views, 4 Replies
Am trying to get the treeview filled with Inventor Treeview details which is present on lrft side.
this is the code i did
Imports System.Uri
Imports System.UriComponents
Imports System.UriParser
Public objAppServComponent AsNew Inventor.ApprenticeServerComponent
Dim objAppServDoc As Inventor.ApprenticeServerDocument
objAppServDoc = objAppServComponent.Open(TextBox1.Text) '''' here i get path of assembly
Dim objTreeNode As New TreeNode(objAppServDoc.DisplayName)
TreeView1.Nodes.Add(objTreeNode)
Call GetComponents(objAppServDoc.ComponentDefinition.Occurrence, objTreeNode)
''''''Getting error on this above line
'''''' reference to Reference to non shared member requires object reference
How to Solve or get Inventor Treeview to customised treeview, any suggestions
Senior Software Engineer
4 REPLIES 4
leefsma
in reply to: amitnkukanur
Hi amitk_189,
The "ComponentDefinition.Occurrence" property does not exist, so it is no wonder that the code you provided generates an error.
Below is a VB.Net sample that illustrates how to parse an assembly structure using a recursive procedure (this Inventor, but adapting it to Apprentice should be straightforward):
    Public Sub AssemblyTraversal()
        Dim oDoc As AssemblyDocument
        oDoc = _InvApplication.ActiveDocument
        'Call the recursive function to iterate through the assembly tree
        Call AssemblyTraversalRec(oDoc.ComponentDefinition.Occurrences, 0)
    End Sub
    Private Sub AssemblyTraversalRec(ByVal InCollection As ComponentOccurrences, ByVal level As Long)
        'Iterate through the components in the current collection
        Dim oCompOccurrence As ComponentOccurrence
        For Each oCompOccurrence In InCollection
            Dim str As String = String.Empty
            If oCompOccurrence.DefinitionDocumentType = DocumentTypeEnum.kAssemblyDocumentObject Then
                str = Space(3 * level) & " - [Asm]  " & oCompOccurrence.Name
            Else
                str = Space(3 * level) & " - [Part] " & oCompOccurrence.Name
            End If
            Debug.WriteLine(str)
            'Recursively call this function for the sub-occurrences of the current component
            Call AssemblyTraversalRec(oCompOccurrence.SubOccurrences, level + 1)
        Next
    End Sub
I hope it helps.
Philippe Leefsma
Developer Consultant
Developer Technical Services
Global Subscription & Support
Autodesk EMEA
www.autodesk.com/joinadn
amitnkukanur
Getting error on
Object reference not set to an instance of an object.
amitnkukanur
Hi i solved that error using the below code
Dim
Dim _InvApplication As Inventor.Application
Dim InvType AsType = GetTypeFromProgID("Inventor.Application", True)
_InvApplication = CreateInstance(InvType)
Dim oDoc As Inventor.AssemblyDocument
'Till here its working but getting error on next line.
spascual
Hi Sirs,
Could you paste the code you wrote ????
