Forms? I think....
2 REPLIES 2
302 Views, 2 Replies
Forms? I think....
I have an assembly of a frame that is enclosed by sheet metal components. I created a skeletal part and used frame generator to create the frame. I am in the process of linking all the parameters required to adjust the frame and all sheet metal components based on changes to the skeletal part file. There is 5 dimensions that will produce the assembly in any size we want. I was at an inventor conference and had a glimpse of a "form" i think it was called. It is a box with various inputs and once those inputs are entered in the form updates the assembly file to match.
I am not 100% sure if this is correct or not, but does anybody kind of know what I am talking about?
Basically what I want it a dialog box with 5 input boxes that will change 5 parameters in my skeletal model and then update the assembly file to match.?!
Thanks for any advice or direction.
I have attached my skeletal model part file for those interested.
Also an image of the assembly - it is much too large to attach
The 5 parameters that i want to change are
  • overall_length
  • overall_width
  • center_divider
  • fork_pocket_centers
  • overall_height ( not really viewable, just been adjusting the workplane dimension)
Sean
Inventor Pro 2013
2 REPLIES 2
in reply to: Curtis_Waguespack
Yup, I checked out some of the videos, looks like what I am looking for...not 100% sure if I will be able to make a form, but I will play around with it and look through the tutorials.
I will post back if I run into any issues.
