Inventor Customization
RPdAnjou
Message 1 of 3 (205 Views)
Finding "Where Used" or recreating the "Open Drawing" command using the API
205 Views, 2 Replies
07-17-2012 04:16 AM
I know there are a few posts about "where used" and opening/printing drawings of all components in a assembly, but to be as flexible as possible I would like to ask about this issue a bit more specific.
The RMB command "Open Drawing" will open the drawing that uses the component.
My question is, how can I reproduce this behavior trough the API?
Even more interesting would be, how can I get a reference to the "Where Used" components. I know components don't know where they are used, but how do I figure this out the easy way with the API.
Can this be done by calling this command directly or can I maybe use the "Design Assistant" trough the API?
My expectation would be that the "Design Assistant" functionalities will be available trough the Inventor API, is this true?
I do not want to search trough the projects search paths with custom code.
The first function I want to use this for is:
When I loop trough the Structured BOM, I would like to open and print all drawings related to the components represented in this BOM view.
Thanks in advance.
ADN Support Specialist
xiaodong.liang
Message 2 of 3 (176 Views)
Re: Finding "Where Used" or recreating the "Open Drawing" co
08-02-2012 01:38 AM in reply to: RPdAnjou
Could you have a look at this blog if it answered your question. It is written by Brian, our API expert .
http://modthemachine.typepad.com/my_weblog/2008/11/file-references-part-2.html
Xiaodong Liang
Developer Technical Services
Autodesk Developer Network
RPdAnjou
Message 3 of 3 (170 Views)
08-02-2012 06:48 AM in reply to: RPdAnjou
That's something I did not find when searching for information about this topic.
While reading the blog:
At first I thought, hey, that's just like other solutions I found don the autodesk customization forum.
But then I also realized, when I open the drawing of a part, it does not have the same name!
We use Productstream Pro (where we can also find Where Used drawings, but that aside) and all documents get unique file names.
So a IDW will never have the same file name as the IPT or IAM.
Are you sure this function only checks file names? I think it also checks referenced files from all found IDW's.
Also, this is not a solution in VBA/.NET because this (Open Drawing) is not a API function, or is it?
Thanks for the info!
You are not logged in.
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
