I'm trying to write a VB.Net program (Visual Studio 2010 Express) for Inventor 2012 that will add up the length of all the edges of a flat pattern including any cutouts/holes in the part. I need the total length to do an estimate on the amount of time required to cut out the pattern on a laser. Any ideas how to get this info programatically in VB?
I found a solution to this here....
I redid it a little thought...
Private Sub GetTotalLength(ByVal oDoc As PartDocument, ByVal enumUnits As UnitsTypeEnum) If Not oDoc.DocumentSubType.DocumentSubTypeID = "{9C464203-9BAE-11D3-8BAD-0060B0CE6BB4}" Then MessageBox.Show("Convert part file to sheet metal and retry...", "Part Not Sheet Metal", MessageBoxButtons.OK) Exit Sub End If Dim oSMDef As SheetMetalComponentDefinition oSMDef = oDoc.ComponentDefinition If Not oSMDef.HasFlatPattern Then MessageBox.Show("Create flat pattern and retry...", "Missing Flat Pattern", MessageBoxButtons.OK) Exit Sub End If Dim suffix As String = "" Dim strFormat As String = "N3" Select Case enumUnits Case UnitsTypeEnum.kInchLengthUnits suffix = "in" strFormat = "N3" Case UnitsTypeEnum.kMillimeterLengthUnits suffix = "mm" strFormat = "N2" Case UnitsTypeEnum.kFootLengthUnits suffix = "ft" strFormat = "N3" Case UnitsTypeEnum.kMeterLengthUnits suffix = "m" strFormat = "N2" End Select Dim oTopFace As Face = oSMDef.FlatPattern.TopFace Dim oBotFace As Face = oSMDef.FlatPattern.BottomFace Dim FlatWidth As Double = oDoc.UnitsOfMeasure.ConvertUnits(oSMDef.FlatPattern.Width, _ UnitsTypeEnum.kDatabaseLengthUnits, _ enumUnits) Dim FlatLength As Double = oDoc.UnitsOfMeasure.ConvertUnits(oSMDef.FlatPattern.Length, _ UnitsTypeEnum.kDatabaseLengthUnits, _ enumUnits) Dim TotalLengthTopInches As Double = GetPerimeterLengthOfFace(oDoc, oTopFace, enumUnits) Dim TotalLengthBotInches As Double = GetPerimeterLengthOfFace(oDoc, oBotFace, enumUnits) Dim CutLength As Double Dim EtchLength As Double If TotalLengthTopInches > TotalLengthBotInches Then CutLength = TotalLengthBotInches EtchLength = TotalLengthTopInches - TotalLengthBotInches Else CutLength = TotalLengthTopInches EtchLength = TotalLengthBotInches - TotalLengthTopInches End If MessageBox.Show("Total Cut length: " & CutLength.ToString(strFormat) & " " & suffix & vbNewLine & _ "Total Etch length: " & EtchLength.ToString(strFormat) & " " & suffix & vbNewLine & _ "Width : " & FlatWidth.ToString(strFormat) & " " & suffix & vbNewLine & _ "Length: " & FlatLength.ToString(strFormat) & " " & suffix, _ "Cut and Etch lengths", _ MessageBoxButtons.OK) End Sub Private Function GetPerimeterLengthOfFace(ByVal oDoc As Document, _ ByVal oFace As Face, _ ByVal enumUnits As UnitsTypeEnum) As Double Dim TotalLength As Double TotalLength = 0 For Each oEdge As Edge In oFace.Edges Dim oEvaluator As CurveEvaluator oEvaluator = oEdge.Evaluator Dim minparam As Double Dim maxparam As Double Call oEvaluator.GetParamExtents(minparam, maxparam) Dim length As Double Call oEvaluator.GetLengthAtParam(minparam, maxparam, length) TotalLength = TotalLength + length Next Dim TotalLengthByEnumUnits As Double TotalLengthByEnumUnits = oDoc.UnitsOfMeasure.ConvertUnits(TotalLength, UnitsTypeEnum.kDatabaseLengthUnits, enumUnits) Return TotalLengthByEnumUnits End Function
Here is a macro I use to make 4 custom iProperties, InternalPerimiters, ExternalPerimeter, TotalPerimiter (sum of the 2 previous) and Pierces (all internal loops+1 for external).
Sub GetIntExtPerimeters() Dim oPartDoc As Document Set oPartDoc = ThisApplication.ActiveDocument Dim oFlatPattern As FlatPattern ' Check for a non-part document If oPartDoc.DocumentType <> kPartDocumentObject Then MsgBox "The Active document must be a 'Part'!" Exit Sub End If ' The Active document must be a Sheet metal Part If oPartDoc.SubType <> "{9C464203-9BAE-11D3-8BAD-0060B0CE6BB4}" Then MsgBox "The 'Part' must be a Sheet Metal Part!" Exit Sub End If ' Check to see if the flat pattern exists. Set oFlatPattern = oPartDoc.ComponentDefinition.FlatPattern If oFlatPattern Is Nothing Then MsgBox "No flat pattern exists for this part!" Exit Sub End If Dim oSheetMetalCompDef As SheetMetalComponentDefinition Set oSheetMetalCompDef = oPartDoc.ComponentDefinition ' Get the cut length Dim oFace As Face Set oFace = oSheetMetalCompDef.FlatPattern.TopFace ' Find the outer loop. Dim dOuterLength As Double dOuterLength = 0 Dim oLoop As EdgeLoop For Each oLoop In oFace.EdgeLoops If oLoop.IsOuterEdgeLoop Then Dim oEdge As Edge For Each oEdge In oLoop.Edges ' Get the length of the current edge. Dim dMin As Double, dMax As Double Call oEdge.Evaluator.GetParamExtents(dMin, dMax) Dim dLength As Double Call oEdge.Evaluator.GetLengthAtParam(dMin, dMax, dLength) dOuterLength = dOuterLength + dLength Next 'MsgBox "Outer Loop is " & FormatNumber(dOuterLength, 1) Exit For End If Next ' Iterate through the inner loops. Dim iLoopCount As Long iLoopCount = 0 Dim dTotalLength As Double For Each oLoop In oFace.EdgeLoops Dim dLoopLength As Double dLoopLength = 0 If Not oLoop.IsOuterEdgeLoop Then For Each oEdge In oLoop.Edges ' Get the length of the current edge. Call oEdge.Evaluator.GetParamExtents(dMin, dMax) Call oEdge.Evaluator.GetLengthAtParam(dMin, dMax, dLength) dLoopLength = dLoopLength + dLength Next ' Add this loop to the total length. dTotalLength = dTotalLength + dLoopLength 'MsgBox "Inner Loops are " & FormatNumber(dTotalLength, 1) End If Next 'added by BH 13-07-2011-count edges to calculate peirces Dim oDoc As PartDocument Set oDoc = ThisApplication.ActiveDocument Dim oDef As SheetMetalComponentDefinition Set oDef = oDoc.ComponentDefinition Set oFlatPattern = oDef.FlatPattern Dim oTransaction As Transaction Set oTransaction = ThisApplication.TransactionManager.StartTransaction(oDoc, "FindArea ") Dim oSketch As PlanarSketch Set oSketch = oFlatPattern.Sketches.Add(oFlatPattern.TopFace) Dim oEdgeLoop As EdgeLoop numLoops = 1 For Each oEdgeLoop In oFlatPattern.TopFace.EdgeLoops If oEdgeLoop.IsOuterEdgeLoop = False Then numLoops = numLoops + 1 End If Next TotalPierces = numLoops For Each oEdgeLoop In oFlatPattern.TopFace.EdgeLoops If oEdgeLoop.IsOuterEdgeLoop Then Exit For End If Next For Each oEdge In oEdgeLoop.Edges Call oSketch.AddByProjectingEntity(oEdge) Next Dim oProfile As Profile Set oProfile = oSketch.Profiles.AddForSolid oTransaction.Abort 'end Dim oUom As UnitsOfMeasure Set oUom = oPartDoc.UnitsOfMeasure outerCutlength = oUom.GetStringFromValue(dOuterLength, kMillimeterLengthUnits) innerCutlength = oUom.GetStringFromValue(dTotalLength, kMillimeterLengthUnits) TotalCutLength = oUom.GetStringFromValue(dTotalLength + dOuterLength, kMillimeterLengthUnits) 'Write data to properties, creating or updating (if property exists) Dim oCustomPropSet As PropertySet Set oCustomPropSet = oPartDoc.PropertySets.Item("{D5CDD505-2E9C-101B-9397-08002B2CF9AE}") On Error Resume Next oCustomPropSet.Item("OuterPerimeter").Value = outerCutlength If Err Then Err.Clear Call oCustomPropSet.Add(outerCutlength, "OuterPerimeter") End If oCustomPropSet.Item("InnerPerimeters").Value = innerCutlength If Err Then Err.Clear Call oCustomPropSet.Add(innerCutlength, "InnerPerimeters") End If oCustomPropSet.Item("TotalPerimeter").Value = TotalCutLength If Err Then Err.Clear Call oCustomPropSet.Add(TotalCutLength, "TotalPerimeter") End If 'added by BH 13-07-2011 oCustomPropSet.Item("Pierces").Value = TotalPierces If Err Then Err.Clear Call oCustomPropSet.Add(TotalPierces, "Pierces") End If End End Sub
Hello BLHDrafting,
Do you have a version of this code that works with Inventor 2014?
Regrads,
Ivon
Brendan,
What happens if the flat pattern includes punches that do not "cut" through the material, i.e. Dimples, louvers, etc. They seem to be included in the inner length calculation.
Neil
Ivon, I'm still on 2013 so I don't know how it goes on 2014. I'm assuming that yu have tried it an it failed. I think there are a few 'reference' that need to be turned on for this to work. I'm on holiday now (4 day weekend) so I won't be able to look at it till Tuesday. I'll post something then.
Neil, I have not used Punches so I don't know. I guess you have tried the code with punches and have seen that they are included in the perimeter values, which is probably not correct depending on your requirements.
I didn't write the code. A colleague from the UK did and I think he has passed on. Someone who knows about this stuff should be able to filter (exclude) these from the perimeter results, and probably be able to create a Punches number if that is part of what they need.
The code works perfectly for my needs. Any full thickness protrusion add's to the inner perimeter count.
Hello Brendan,
I restarted inventor and it works fine. I didn't think a restart would have been required.
Ivon
Hi
did you manage to get this to work in 2014 version?
I have tried and kept getting errors even after I rebooted
Regards
Mark
Hello Mark,
When using VBA Editor in Inventor I copied a version of the macro into the ApplicatioProject (Default.ivb).
Once the file is located in default.ivb location it works for all files.
Once this is done I made a short cut by customizing my toolbar. To automate the process I created a iLogc rule to call up the macro....
Here is the iLogic rule...
InventorVb.RunMacro("ApplicationProject", "sheetmetal3", "GetIntExtPerimeters")
I added this to the event triggers...
I hope this helps.
Hi Ivon
Thanks I was getting a bit worried when I tried to run the debug it came up with errors, I had also pre entered the custome properties which I think may not have helped but it looks to be working now
Regards
Mark
hello friend, ı applied your code and ı get some error. Can you help me to solve my issues pls.
after ı run program ı get a warning "All other sub's or function's must be after Sub Main ()
why do ı get this warning?
Hello Brendan,
I tried to call this macro from a differnt macro to automate the part information and had trouble. I took a long time to debug.
I commented out the end prior to the end sub. This seemed to work.
'added by BH 13-07-2011 oCustomPropSet.Item("Pierces").Value = TotalPierces If Err Then Err.Clear Call oCustomPropSet.Add(TotalPierces, "Pierces") End If 'End 'This end causes the macros to stop any further action. End Sub
I hope this helps.
Hi Brendan,
Is there any simple way to modify a snipped given below to make it useful as direct iLogic code?
I try to rewrite Your macro to direct iLogic code. As result I get perimeters in "cm". I'd like to change units to "mm"
Thanks in advance for help
Tomek
I've handeled somehow with the rule for laser cutting time calculation. Now I'd like to edit the rule to have one single rule working both for a single file and an assembly. Below You can find the rule Ive prepared. Works fine for a single sheet metal file. The problem is when it starts with the assembly. I looks like the rule is not able to read the the parameter thickness of a sheet metal part within the assembly. Mayby somebody will be able to repair it.
Sub Main Czas_Palenia_Laser () Dim oFile As Document oFile = ThisDoc.Document If oFile.DocumentType = kPartDocumentObject Then Call Part(oFile) End If If oFile.DocumentType = kAssemblyDocumentObject Then Call Assy(oFile) End If End Sub Sub Assy (oDoc As Document) 'oDoc = ThisApplication.ActiveDocument Dim oAsmDoc As AssemblyDocument oAsmDoc = ThisApplication.ActiveDocument 'Zmiany 12.07.2019 oCompDef = oAsmDoc.ComponentDefinition Dim oRefDocs As DocumentsEnumerator oRefDocs = oDoc.AllReferencedDocuments Dim oRefDoc As Document For Each oRefDoc In oRefDocs If oRefDoc.DocumentType = kPartDocumentObject Then If oRefDoc.IsModifiable = True Then 'Wyklucza elementy należące do biblioteki części m.in. śruby, nakrętki itp. If oRefDoc.SubType = "{9C464203-9BAE-11D3-8BAD-0060B0CE6BB4}" Then 'Sprawdza czy część wchodząca w skład złożenia została utworzona z wykorzystaniem szablonu konstrukcja blachowa. ThisApplication.Documents.Open(oRefDoc.FullFileName, True) Call Part(oRefDoc) oRefDoc.Close Else End If Else End If End If Next End Sub Sub Part (oDoc As Document) 'oDoc = ThisApplication.ActiveDocument Dim oSMDef As SheetMetalComponentDefinition oSMDef = oDoc.ComponentDefinition If oSMDef.HasFlatPattern = False Then oSMDef.Unfold oSMDef.FlatPattern.ExitEdit End If Dim oFlatPattern As FlatPattern oFlatPattern = oDoc.ComponentDefinition.FlatPattern Dim oFace As Face oFace = oSMDef.FlatPattern.TopFace Dim oOuterLength As Integer oOuterLength = 0 Dim oLoop As EdgeLoop Dim dMax, dMin, dLength As Double Dim oEdge As Edge For Each oLoop In oFace.EdgeLoops If oLoop.IsOuterEdgeLoop Then For Each oEdge In oLoop.Edges Call oEdge.Evaluator.GetParamExtents(dMin, dMax) Call oEdge.Evaluator.GetLengthAtParam(dMin, dMax, dLength) oOuterLength = oOuterLength + dLength Next Exit For End If Next '--> MessageBox.Show(oOuterLength, "iLogic Test Value No1") Dim iLoopCount As Long iLoopCount = 0 Dim oInnerLength,oLoopLength As Double For Each oLoop In oFace.EdgeLoops oLoopLength = 0 If Not oLoop.IsOuterEdgeLoop Then For Each oEdge In oLoop.Edges Call oEdge.Evaluator.GetParamExtents(dMin, dMax) Call oEdge.Evaluator.GetLengthAtParam(dMin, dMax, dLength) oLoopLength = oLoopLength + dLength Next oInnerLength = oInnerLength + oLoopLength 'Oblicza całkowitą dł. pętli (sumę obowdów) wew. detalu. End If Next '--> MessageBox.Show(oTotalLength, "iLogic Test Value No2") Dim oTransaction As Transaction oTransaction = ThisApplication.TransactionManager.StartTransaction(oDoc, "FindArea ") Dim oSketch As PlanarSketch oSketch = oFlatPattern.Sketches.Add(oFlatPattern.TopFace) Dim oEdgeLoop As EdgeLoop numLoops = 1 For Each oEdgeLoop In oFlatPattern.TopFace.EdgeLoops If oEdgeLoop.IsOuterEdgeLoop = False Then numLoops = numLoops + 1 End If Next Dim NoPierces As Double NoPierces = numLoops 'WPALENIA !!!! '--> MessageBox.Show(NoPierces, "iLogic Test Value No3") For Each oEdgeLoop In oFlatPattern.TopFace.EdgeLoops If oEdgeLoop.IsOuterEdgeLoop Then Exit For End If Next For Each oEdge In oEdgeLoop.Edges Call oSketch.AddByProjectingEntity(oEdge) Next Dim oProfile As Profile oProfile = oSketch.Profiles.AddForSolid oTransaction.Abort '------------------------------------------------------------------------------------------------------------- 'Konwersja zmiennych tak by możliwe było zapisanie wartości parametrów jako niestandardowe wartości iLogic Dim oUom As UnitsOfMeasure Dim oLengthUnits As String oUom = oDoc.UnitsOfMeasure oLengthUnits = oUom.GetStringFromType(oUom.LengthUnits) OuterCutLength = oUom.GetStringFromValue(oOuterLength, oLengthUnits) InnerCutlength = oUom.GetStringFromValue(oInnerLength, oLengthUnits) TotalCutLength = oUom.GetStringFromValue(oInnerLength + oOuterLength, oLengthUnits) '--> MessageBox.Show(OuterCutLength & " " & InnerCutlength & " " & TotalCutLength , "iLogic Test Value No4") '------------------------------------------------------------------------------------------------------------- 'Zapisywanie parametrów jako niestandardowe wartości iLogic Dim oCustomPropSet As PropertySet oCustomPropSet = oDoc.PropertySets.Item("{D5CDD505-2E9C-101B-9397-08002B2CF9AE}") Try oCustomPropSet.Add(OuterCutLength, "Dł. zew. krawędzi") Catch iProperties.Value ("Custom","Dł. zew. krawędzi") = OuterCutLength End Try Try oCustomPropSet.Add(InnerCutLength, "Dł. wew. krawędzi") Catch iProperties.Value ("Custom","Dł. wew. krawędzi") = InnerCutLength End Try Try oCustomPropSet.Add(TotalCutLength, "Całk. dł. krawędzi") Catch iProperties.Value ("Custom","Całk. dł. krawędzi") = TotalCutLength End Try Try oCustomPropSet.Add(CStr(NoPierces), "Ilość wpaleń") Catch iProperties.Value ("Custom","Ilość wpaleń") = CStr(NoPierces) End Try '--------------------------------------------------------------------------------------------------------------------- 'Wybór materiału oMaterialArray = New String(){"STAL", "STAL NIERDZEWNA", "STAL GALWANIZOWANA", "ALUMINIUM"} oMaterial = InputListBox("Z powyższej listy wybierz rodzaj materiału z którego wykonany jest detal",oMaterialArray, "Stal", "iLogic", "Wybierz rodzaj materiału") '--------------------------------------------------------------------------------------------------------------------- 'Dobór wartości posuwu głowicy Dim FeedRate, Thickness As Double Try Thickness = oDoc.ComponentDefinition.Parameters("Grubość") 'Pobiera parametr grubość przypisany do konstrukcji blachowej Catch Thickness = oDoc.ComponentDefinition.Parameters("Thickness") End Try 'If Thickness Is Nothing Then 'MessageBox.Show("Wystąpił problem z pobraniem parametru grubość z modelu", "iLogic") 'Exit Sub 'End If Try MaterialName = oDoc.ComponentDefinition.Material.Name 'Pobiera dane dot. materiału przypisanego do modelu. Catch MessageBox.Show("Wystąpił problem z pobraniem danych dot. materiału przypisanego do modelu", "iLogic") End Try If oMaterial = "STAL" Then Select Case Thickness Case 1 FeedRate = 5500 '8300 Case 1.4 To 1.6 FeedRate = 4500 '6500 Case 2.5 FeedRate = 4000 Case 2 FeedRate = 3500 '6000 Case 2.9 To 3.1 FeedRate = 2000 '3500 Case 4 FeedRate = 2500 '3500 Case 4.9 To 5.1 FeedRate = 2000 '2700 Case 5.9 To 6.1 FeedRate = 1900 '2400 Case 8 FeedRate = 1200 '1900 Case 10 FeedRate = 1100 '1400 Case 11.9 To 12.1 FeedRate = 1000 '1100 Case 15 FeedRate = 800 '950 Case 16 FeedRate = 700 Case 20 FeedRate = 650 '650 End Select Else End If If oMaterial = "STAL NIERDZEWNA" Then Select Case Thickness Case 1: FeedRate = 5000 '9000 Case 1.4 To 1.6 FeedRate = 4200 Case 2: FeedRate = 2500 '6100 Case 2.9 To 3.1 FeedRate = 1800 '3800 Case 4: FeedRate = 1800 '2500 Case 5: FeedRate = 1600 '2000 Case 5.9 To 6.1 FeedRate = 1400 Case 8: FeedRate = 1000 '800 Case 10: FeedRate = 800 '650 Case 12: FeedRate = 800 '270 End Select Else End If If oMaterial = "STAL GALWANIZOWANA" Then Select Case Thickness Case 1: FeedRate = 5500 '9000 Case 1.25: FeedRate = 5000 '6500 Case 1.4 To 1.55 FeedRate = 4500 '7500 Case 2: FeedRate = 3500 '6000 Case 2.9 To 3.1 FeedRate = 2000 '3000 End Select Else End If If oMaterial = "ALUMINIUM" Then Select Case Thickness Case 1: FeedRate = 5500 '9000 Case 1.5: FeedRate = 4700 '7300 Case 2: FeedRate = 4000 '5800 Case 2.5: FeedRate = 3900 '4300 Case 2.9 To 3.1 FeedRate = 2300 '2900 Case 4: FeedRate = 1900 '2400 Case 5: FeedRate = 1600 '1800 Case 6: FeedRate = 1500 '1400 Case 8: FeedRate = 1000 '750 End Select Else End If If FeedRate = 0 Then MessageBox.Show("Wystąpił problem z doborem prędkości posuwu głowicy!" _ & vbLf _ & vbLf & "Materiał przypisany do modelu: " & MaterialName _ & vbLf _ & vbLf & "Grubość materiału: " & Thickness & " mm" _ & vbLf _ & vbLf & "Wybrana wartość posuwu: " & FeedRate & " [mm/min]" _ & vbLf _ & vbLf & "Sprawdź ustawienia materiału przypiasanego do modelu i uruchom regułę ponownie", "iLogic") Exit Sub End If '-->MessageBox.Show(FeedRate, "iLogic") '----------------------------------------------------------------------------------------------------------------------------------------------------------------- ' OBLICZENIA Dim totalPierces As Double PierceDeclar = MessageBox.Show ("Czy chcesz zdefiniować ilość wpaleń danego typu: puls/normalne?" _ & vbLf & " " _ & vbLf & "Wybierz TAK aby zdefiniować ilości wpaleń danego typu." _ & vbLf & " " _ & vbLf & "Wybierz NIE - wszystkie występujące wpalenia zostaną uwzględnione jako normalne" _ & vbLf & " " _ & vbLf & "Wpalenia typu puls znajdują zastosowanie w przypadku gdy śr. otworu jest mniejsza lub równa od grubości palonego materiału", "iLogic", MessageBoxButtons.YesNo, MessageBoxIcon.Information, MessageBoxDefaultButton.Button2) If PierceDeclar = vbYes Then Do nPierces = InputBox("Podaj ilość wpaleń normalne:" _ & vbLf _ & vbLf & "Wszystkie wpalenia: " & NoPierces,"iLogic", 0) pPierces = InputBox("Podaj ilość wpaleń puls:" _ & vbLf _ & vbLf & "Wszystkie wpalenia: " & NoPierces _ & vbLf _ & vbLf & "Wpalenia normalne: " & nPierces,"iLogic", 0) If nPierces = "" Then Exit Sub End If pPierces_value = CDbl(pPierces) 'Function to convert string value into a double nPierces_value = CDbl(nPierces) totalPierces = nPierces_value + pPierces_value If totalPierces <> NoPierces Then MessageBox.Show("Zadeklarowano niewłaściwą ilość wpaleń!" _ & vbLf _ & vbLf & "Podaj prawidłową sumaryczną ilość wpaleń", "iLogic") End If Loop Until totalPierces = NoPierces 'Pętla wymusza na użytkowniku podanie prawidłowej ilości wpaleń, co ogranicza ryzyko błędu 'Return Else nPierces_value = CDbl(NoPierces) End If Dim EdgeCutTime As Double If oInnerLength = 0 Then EdgeCutTime = ((oOuterLength*10) / FeedRate) 'Przypadek gdy detal ma tylko obrys zewnętrzny, mnożnik x10 dodano aby przeliczyć jednostki cm -> mm Else Dim PerimeterFactor As Double PerimeterFactor = Math.Round((oOuterLength / oInnerLength), 2, MidpointRounding.AwayFromZero) 'Współczynnik opisujący stosunek obwodu zewnętrzengo do wewnętrznego. Select Case PerimeterFactor Case <=2.5: EdgeCutTime = ((((oInnerLength + oOuterLength)*10) / FeedRate)*PerimeterFactor) 'MessageBox.Show("Case 1", "iLogic") Case 2.5 To 3.5: EdgeCutTime = ((((oInnerLength + oOuterLength)*10)/ FeedRate)*(PerimeterFactor/2.5)) 'MessageBox.Show("Case 2", "iLogic") Case 3.5 To 5.5: EdgeCutTime = ((((oInnerLength + oOuterLength)*10) / FeedRate)*(PerimeterFactor/3.5)) 'MessageBox.Show("Case 3", "iLogic") Case Else: EdgeCutTime = (((oInnerLength + oOuterLength)*10) / FeedRate) 'MessageBox.Show("Case 4", "iLogic") End Select End If Dim CutTime, WynikIFS As Double 'MessageBox.Show(EdgeCutTime, "iLogic") CutTime = EdgeCutTime + ((nPierces_value * 0.025) + (pPierces_value * 0.055)) Dim Wynik As String Wynik = Math.Round(CutTime,2, MidpointRounding.AwayFromZero).ToString("0.00") WynikIFS = Math.Round((Wynik * 0.0167),3,MidpointRounding.AwayFromZero) '------------------------------------------------------------------------------------------- ' PREZENTACJA WYNIKÓW MessageBox.Show("Gatunek blachy: " & MaterialName _ &vbLf _ &vbLf & "Grubość blachy: " & Thickness & " mm." _ &vbLf _ &vbLf & "Ilość wpaleń: " & nPierces_value _ &vbLf _ &vbLf & "Prędkość posuwu: " & FeedRate & " mm/min." _ &vbLf _ &vbLf & "Czas palenia Laser: " & Wynik & " min." & " (" & WynikIFS & ") ", "iLogic") '&vbLf & "Współczynnik: " & PerimeterFactor _ 'Wyświetla wartość współczynnika. '&vbLf _ Try oCustomPropSet.Add(WynikIFS, "Czas palenia") Catch iProperties.Value("Custom","Czas palenia") = WynikIFS End Try RuleParametersOutput() InventorVb.DocumentUpdate() End Sub
Thanks in advance for help.
Tomek
