Inventor Programming - iLogic, Macros, AddIns & Apprentice
Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
Export face to DWG + info
4 REPLIES 4
419 Views, 4 Replies
Hi all,
I need to find a way to export the selected face to dwg and to have the Part Number and if possible the description written under the exported face. I don't know if it's possible to do this. I know it's possible to export programmatically the selected face, but is it possible to get the name + description into the drawing too?
We're just looking for a way to "automate" the creation of our laser drawings..
4 REPLIES 4
Is it a plate or a solid?
where is the name and description?
Vladimir.Ananyev
It would be nice to see some samples - your typical face in Inventor and the same face in AutoCAD with required text labels.
Do you work with planar faces only or not?
Vladimir Ananyev
Developer Technical Services
Autodesk Developer Network
I've finally decided to export the flat pattern since all our laser parts should be drawn as sheet metal. I wanted the export face because that is currently what we use to make our laser drawings.
Thanks for trying to help me anyway and sorry for the late response
adam.nagy
Hi there,
No problem. 🙂
As I understand you have a working solution now? - that's the main thing.
Cheers,
Adam Nagy
Autodesk Platform Services
