Can not get the PDF translator Add-In
Trying to export a PDF with PDF translator. Using sample "Save as PDF Translator Sample" from programers help as guild.
Getting error "Unspecified error (Exception from HRESULT: 0x80004005 (E_FAIL))" with
Dim PDFAddIn As TranslatorAddIn = ThisApplication.ApplicationAddIns.ItemById("{0AC6FD96-2F4D-42CE-8BE0-8AEA580399E4}")
Tried on another system with same results. Can get other translators with ItemById. Can export PDF manually.
Inventor 2014, Visual Studios 2012
(this is sort of a repost of http://forums.autodesk.com/t5/Autodesk-Inventor-Customization/error-with-ThisApplication-Application... that got marked solved)
Stan
I don't think you can set an object like that in VBA
Try it like this
Dim PDFAddIn As TranslatorAddIn Set PDFAddIn = ThisApplication.ApplicationAddIns.ItemById("{0AC6FD96-2F4D-42CE-8BE0-8AEA580399E4}")
Daniël
Check if you have the PDF translator in the list of translators at the Addin manager. It should be there with load behavior automatic/on demand.
Do you get the same error when trying from VBA? Works fine on my side...
If VBA works, can you post the full Vb.Net code?
Public Sub PublishPDF() Dim translator As TranslatorAddIn Set translator = ThisApplication.ApplicationAddIns.ItemById("{0AC6FD95-2F4D-42CE-8BE0-8AEA580399E4}") Dim doc As Document Set doc = ThisApplication.ActiveDocument Dim ctx As TranslationContext Set ctx = ThisApplication.TransientObjects.CreateTranslationContext ctx.Type = kFileBrowseIOMechanism ' Create a NameValueMap object Dim options As NameValueMap Set options = ThisApplication.TransientObjects.CreateNameValueMap ' Create a DataMedium object Dim dataMedium As dataMedium Set dataMedium = ThisApplication.TransientObjects.CreateDataMedium 'Set the destination file name dataMedium.filename = "c:\Temp\test.pdf" 'Publish document. Call translator.saveCopyAs(doc, ctx, options, dataMedium) End Sub
Philippe.
Tried on other systems with same results. Manually exporting to PDF works on all.
Windows 7 64 bit inventor professional 2014 build 170, update 1 (Tried VB.net and VBA)
Windows 8 64 bit inventor professional 2014 build 170 (Tried VB.net, system on differnt network... off site)
Windows 7 64 bit inventor 2014 build 170 (Tried VBA)
Windows 7 64 bit inventor 2013 build 176 sp1.1 (Tried VBA, same system as above)
All systems had 2014 installed with 2013 already installed. Two systems had 2013 uninstalled after.
Could there be a regional change with PDF addin ID? These systems are in Canada, Software was downloaded through subscription.
You can check the class id of the addin. Go to: C:\ProgramData\Autodesk\Inventor 2014\Addins and look for this file: Autodesk.TranslatorPDF.Inventor.addin
If you open this file with notepad you can find the class id somewhere in the first couple of lines.
Well this is embarrassing...
When I checked the addin ID I discovered a "?" got added in the ID when I pasted the VBA code over to the editor. So VBA works so must be a problem in my VB.net code.
When I get time I will start a new VB.net project and just grab the PDF translator to see what happens. Oddly other translators work fine...
Made a new addin with template and added two buttons. On gets the PDF translator and the other gets the STEP translator. PDF fails, STEP works.
Imports Inventor Imports System.Runtime.InteropServices Imports Microsoft.Win32 Namespace InventorAddIn1 <ProgIdAttribute("InventorAddIn2.StandardAddInServer"), _ GuidAttribute("6a980868-cdce-4631-a170-77a49bf32c15")> _ Public Class StandardAddInServer Implements Inventor.ApplicationAddInServer ' Inventor application object. Private m_inventorApplication As Inventor.Application Private WithEvents _GetPdfTraslatorButton As Inventor.ButtonDefinition Private WithEvents _GetStepTraslatorButton As Inventor.ButtonDefinition Public Shared AddInCLSID As String #Region "ApplicationAddInServer Members" Public Sub Activate(ByVal addInSiteObject As Inventor.ApplicationAddInSite, ByVal firstTime As Boolean) Implements Inventor.ApplicationAddInServer.Activate Try ' This method is called by Inventor when it loads the AddIn. ' The AddInSiteObject provides access to the Inventor Application object. ' The FirstTime flag indicates if the AddIn is loaded for the first time. ' Initialize AddIn members. m_inventorApplication = addInSiteObject.Application ' TODO: Add ApplicationAddInServer.Activate implementation. ' e.g. event initialization, command creation etc. Dim _AddInCLSID As GuidAttribute = CType(System.Attribute.GetCustomAttribute(GetType(StandardAddInServer), GetType(GuidAttribute)), GuidAttribute) AddInCLSID = "{" & _AddInCLSID.Value & "}" Dim UserInterfaceManager As UserInterfaceManager = m_inventorApplication.UserInterfaceManager ' Get the ribbon associated with part documents Dim DrawingRibbon As Ribbon = UserInterfaceManager.Ribbons.Item("Drawing") ' Create a new tab Dim InventorAddIn2Tab As RibbonTab = DrawingRibbon.RibbonTabs.Add("InventorAddIn2", "InventorAddIn2.TranslatorsTab", AddInCLSID, , , False) ' Create a new panel within the tab Dim TranslatorsRibbonPanel As RibbonPanel = InventorAddIn2Tab.RibbonPanels.Add("Translators", "InventorAddIn2.TranslatorsTab.TranslatorsPanel", AddInCLSID) 'Get icon Dim IconIPictureDisp As Object = System.Type.Missing 'create the commands for the environment Dim ControlDefinitions As Inventor.ControlDefinitions = m_inventorApplication.CommandManager.ControlDefinitions _GetPdfTraslatorButton = ControlDefinitions.AddButtonDefinition("Get PDF translator", "InventorAddIn2.GetPdfTraslatorCmd", Inventor.CommandTypesEnum.kQueryOnlyCmdType, AddInCLSID, , , IconIPictureDisp, IconIPictureDisp) _GetStepTraslatorButton = ControlDefinitions.AddButtonDefinition("Get STEP translator", "InventorAddIn2.GetStepTraslatorCmd", Inventor.CommandTypesEnum.kQueryOnlyCmdType, AddInCLSID, , , IconIPictureDisp, IconIPictureDisp) ' Create a control within the panel Call TranslatorsRibbonPanel.CommandControls.AddButton(_GetPdfTraslatorButton, True) Call TranslatorsRibbonPanel.CommandControls.AddButton(_GetStepTraslatorButton, True) Catch ex As Exception MsgBox(ex.ToString) End Try End Sub Public Sub Deactivate() Implements Inventor.ApplicationAddInServer.Deactivate ' This method is called by Inventor when the AddIn is unloaded. ' The AddIn will be unloaded either manually by the user or ' when the Inventor session is terminated. ' TODO: Add ApplicationAddInServer.Deactivate implementation ' Release objects. m_inventorApplication = Nothing System.GC.Collect() System.GC.WaitForPendingFinalizers() End Sub Public ReadOnly Property Automation() As Object Implements Inventor.ApplicationAddInServer.Automation ' This property is provided to allow the AddIn to expose an API ' of its own to other programs. Typically, this would be done by ' implementing the AddIn's API interface in a class and returning ' that class object through this property. Get Return Nothing End Get End Property Public Sub ExecuteCommand(ByVal commandID As Integer) Implements Inventor.ApplicationAddInServer.ExecuteCommand ' Note:this method is now obsolete, you should use the ' ControlDefinition functionality for implementing commands. End Sub #End Region Private Sub _GetPdfTraslatorButton_OnExecute(Context As NameValueMap) Handles _GetPdfTraslatorButton.OnExecute Try Dim PdfTranslator As TranslatorAddIn PdfTranslator = m_inventorApplication.ApplicationAddIns.ItemById("{0AC6FD96-2F4D-42CE-8BE0-8AEA580399E4}") MsgBox("PDF TranslatorAddIn found") Catch ex As Exception MsgBox(ex.ToString) End Try End Sub Private Sub _GetStepTraslatorButton_OnExecute(Context As NameValueMap) Handles _GetStepTraslatorButton.OnExecute Try Dim StepTranslator As TranslatorAddIn StepTranslator = m_inventorApplication.ApplicationAddIns.ItemById("{90AF7F40-0C01-11D5-8E83-0010B541CD80}") MsgBox("STEP TranslatorAddIn found") Catch ex As Exception MsgBox(ex.ToString) End Try End Sub End Class End Namespace
I am also facing the same issue.... tried for the past two days... But not able to find the solution... can any one help iin this issue
Thanks in Advance
