Is there a way or has anyone made a program that can relate the coordinates from the model into the drawings. This would be very helpful so that elevations can be carried through from the model to the drawing. For example when doing a structural tower or anything else that has elevations it is logical to have put the part at the correct elevation in the model. This way when you are doing the drawings you can bring that elevation information through. It is needed to show the construction company and for a check it helps also.
