Inventor Customization
Valued Mentor
JohanLarsson
Message 1 of 7 (313 Views)
DriveConstraintSettings.PlayForward does not animate nor detect contact
313 Views, 6 Replies
10-31-2011 01:55 PM
I played around with the drive constraint and detect contact. It looks really nice and have potential to be really useful.
I wrote a small snippet to try iot from code, but ran into some problems.
 Public Sub driveConstraint()
'    Dim testDoc As AssemblyDocument
    Set testDoc = ThisApplication.ActiveDocument
    Dim constraint As AssemblyConstraint
    For Each constraint In testDoc.ComponentDefinition.Constraints
        If constraint.DriveConstraintSettings.IsInitialized Then
            Exit For
        End If
    Next
    constraint.DriveConstraintSettings.GoToStart
    constraint.DriveConstraintSettings.PlayForward
End Sub
I see two things that differ from when I run the constraint from code compared to when I do the same via inventor GUI.
PlayForward moves the constraint to the end in one step.
Neither collision detection nor contact detection works.
What have i done wrong?
Inventor Professional 2012 SP1 (25 seats with subscription)
Windows 7 64 bit
Lenovo D20, 12 GB RAM, Intel Xeon X5687 3.6 GHz, SSD
Quadro 4000, driver 8.17.12.9573, dual monitors
SpacePilot, driver version 6.15.3 Firmware 3.12
Valued Mentor
JohanLarsson
Message 2 of 7 (309 Views)
Re: DriveConstraintSettings.PlayForward does not animate nor detect contact
10-31-2011 02:37 PM in reply to: JohanLarsson
Inventor 2012 64 Installed SP1, still does not work.
Added some more nonsense code but it does not animate.
            Exit For
        End If
    Next
    Call constraint.DriveConstraintSettings.GoToStart
    Call constraint.DriveConstraintSettings.PlayForward
    Call constraint.DriveConstraintSettings.PlayReverse
    Call constraint.DriveConstraintSettings.StepForward
    Call constraint.DriveConstraintSettings.StepReverse
End Sub
Windows 7 64 bit
Valued Mentor
JohanLarsson
Message 3 of 7 (308 Views)
10-31-2011 03:01 PM in reply to: JohanLarsson
I'm on to something, it seems Inventor does not like the startvalue to be greater than the endvalue. Gonna play around som more and see if I can isolate it.
Windows 7 64 bit
Valued Mentor
JohanLarsson
Message 4 of 7 (301 Views)
11-01-2011 06:03 AM in reply to: JohanLarsson
Now it kinda works, Inventor does not sem to like the StartValue to be less than the EndValue.
The following code animates properly.
Public Sub MeasureByContact()
    Dim assyDoc As AssemblyDocument
    Set assyDoc = ThisApplication.ActiveDocument
    Dim oConstraint As AssemblyConstraint
    For Each oConstraint In assyDoc.ComponentDefinition.Constraints
        If oConstraint.DriveConstraintSettings.IsInitialized Then
            With oConstraint.DriveConstraintSettings
                .StartValue = 0
                .EndValue = 20
                .GoToStart
                .PlayForward
                .StartValue = -20
                .EndValue = 0
                .GoToEnd
                .PlayReverse
            End With
        End If
    Next
End Sub
 One thing remains, to stop at contact. The document is setup to detect contact and when I drive the constraint manually it stops perfectly on contact. When I run it from code it does not stop. Gonna dive into it, please post suggestions if you guys have any.
Windows 7 64 bit
Valued Mentor
JohanLarsson
Message 5 of 7 (300 Views)
11-01-2011 07:06 AM in reply to: JohanLarsson
CollisionDetection does not seem to have the same meaning from the API as from the GUI setting it to true gives me the behaviour I want.
The "Activate Contact Solver" seems to be toggled automatically.
One word of caution, if the stepsize is to large the contact can fail to be detected.
    assyDoc.ModelingSettings.InteractiveContactAnalysis = kAllComponentsInteractiveContact
    assyDoc.ModelingSettings.InteractiveContactSurfaces = kAllSurfacesInteractiveContact
                .CollisionDetection = True
                .StartValue = 0
                .EndValue = 20
                .GoToStart
                .PlayForward
                .StartValue = -20
                .EndValue = 0
                .GoToEnd
                .PlayReverse
            End With
        End If
    Next
End Sub
Windows 7 64 bit
Valued Mentor
JohanLarsson
Message 6 of 7 (289 Views)
11-02-2011 07:07 AM in reply to: JohanLarsson
The corresponding code from .Net:
Caution, this is just a quick hack and will not work for all types of constraints. The unitsconversion is hardcoded to convert to Inventor.UnitsTypeEnum.kDatabaseLengthUnits
Probably numerous bugs, but they are free:smileywink:
        /// <summary>
        ///A test for DriveConstraint
        ///</summary>
        [TestMethod()]
        public void DriveConstraint()
            Inventor.AssemblyDocument assemblyDocument = GetActiveAssemblyDocument();
            assemblyDocument.ModelingSettings.InteractiveContactAnalysis =
                Inventor.InteractiveContactAnalysisEnum.kAllComponentsInteractiveContact;
            assemblyDocument.ModelingSettings.InteractiveContactSurfaces =
                Inventor.InteractiveContactSurfacesEnum.kAllSurfacesInteractiveContact;
            foreach (Inventor.AssemblyConstraint constraint in assemblyDocument.ComponentDefinition.Constraints)
                if(constraint.DriveConstraintSettings.IsInitialized)
                    constraint.DriveConstraintSettings.CollisionDetection = true;
                    constraint.DriveConstraintSettings.SetIncrement(Inventor.ConstraintIncrementTypeEnum.kIncrementAsAmountOfValue, GetExpressionString(assemblyDocument,2,Inventor.UnitsTypeEnum.kMillimeterLengthUnits));
                    constraint.DriveConstraintSettings.StartValue = GetExpressionString(assemblyDocument, 0,
        kMillimeterLengthUnits);
                    constraint.DriveConstraintSettings.EndValue = GetExpressionString(assemblyDocument, 20,
                    constraint.DriveConstraintSettings.GoToStart();
                    constraint.DriveConstraintSettings.PlayForward();
                    constraint.DriveConstraintSettings.StartValue = GetExpressionString(assemblyDocument, -20,
                    constraint.DriveConstraintSettings.EndValue = GetExpressionString(assemblyDocument, 0,
                    constraint.DriveConstraintSettings.GoToEnd();
                    constraint.DriveConstraintSettings.PlayReverse();
            Assert.Inconclusive("A method that does not return a value cannot be verified.");
        private string GetExpressionString(Inventor.AssemblyDocument assemblyDocument, double value, Inventor.UnitsTypeEnum unitsTypeEnum)
            double convertedValue = assemblyDocument.UnitsOfMeasure.ConvertUnits(value, unitsTypeEnum,
        kDatabaseLengthUnits);
            string expressionString=assemblyDocument.UnitsOfMeasure.GetStringFromValue(convertedValue,
                                                   Inventor.UnitsTypeEnum.kMillimeterLengthUnits);
            return expressionString;
        public static Inventor.AssemblyDocument GetActiveAssemblyDocument()
            if (!(InventorUtilities.GetInvetorActiveDocument() is AssemblyDocument))
                throw new InstanceNotFoundException("No active asseblydocument");
            Inventor.AssemblyDocument assemblyDocument = InventorUtilities.GetInvetorActiveDocument() as AssemblyDocument;
            if (assemblyDocument == null) throw new InstanceNotFoundException("No active asseblydocument");
            return assemblyDocument;
Windows 7 64 bit
Valued Mentor
JohanLarsson
Message 7 of 7 (285 Views)
11-02-2011 10:42 AM in reply to: JohanLarsson
Refactored it a bit nicer:
    public static class AssemblyConstraintUtilities
        public static void DriveConstraint(Inventor.AssemblyConstraint assemblyConstraint, double fromPosition, double toPosition, Inventor.UnitsTypeEnum unitsTypeEnum, bool analyzeContact)
            if (assemblyConstraint == null) throw new ArgumentNullException("assemblyConstraint");
            if (Math.Abs(fromPosition - toPosition) < double.Epsilon) throw new InvalidOperationException("Startvalue == Endvalue");
            Inventor.AssemblyDocument assemblyDocument = assemblyConstraint.Parent.Document;
            Inventor.UnitsOfMeasure unitsOfMeasure = assemblyDocument.UnitsOfMeasure;
            assemblyDocument.ModelingSettings.InteractiveContactAnalysis = Inventor.InteractiveContactAnalysisEnum.kAllComponentsInteractiveContact;
            assemblyDocument.ModelingSettings.InteractiveContactSurfaces = Inventor.InteractiveContactSurfacesEnum.kAllSurfacesInteractiveContact;
            Inventor.UnitsTypeEnum dataBaseUnitEnum = GetDataBaseUnitEnum(assemblyConstraint);
            assemblyConstraint.DriveConstraintSettings.CollisionDetection = analyzeContact;
            string incrementExpressionString = InventorUtilities.GetExpressionString(unitsOfMeasure, 1, unitsTypeEnum, dataBaseUnitEnum);
            assemblyConstraint.DriveConstraintSettings.SetIncrement(Inventor.ConstraintIncrementTypeEnum.kIncrementAsAmountOfValue, incrementExpressionString);
            string fromExpressionString = InventorUtilities.GetExpressionString(unitsOfMeasure, fromPosition, unitsTypeEnum, dataBaseUnitEnum);
            string toExpressionString = InventorUtilities.GetExpressionString(unitsOfMeasure, toPosition, unitsTypeEnum, dataBaseUnitEnum);
            if (fromPosition > toPosition)
                DriveConstraintInNegativeDirection(assemblyConstraint, fromExpressionString, toExpressionString);
            else if (fromPosition < toPosition)
                DriveConstraintInPositiveDirection(assemblyConstraint, fromExpressionString, toExpressionString);
        private static void DriveConstraintInNegativeDirection(AssemblyConstraint assemblyConstraint, string fromExpressionString, string toExpressionString)
            assemblyConstraint.DriveConstraintSettings.StartValue = toExpressionString;
            assemblyConstraint.DriveConstraintSettings.EndValue = fromExpressionString;
            assemblyConstraint.DriveConstraintSettings.GoToEnd();
            assemblyConstraint.DriveConstraintSettings.PlayReverse();
        private static void DriveConstraintInPositiveDirection(AssemblyConstraint assemblyConstraint, string fromExpressionString, string toExpressionString)
            assemblyConstraint.DriveConstraintSettings.StartValue = fromExpressionString;
            assemblyConstraint.DriveConstraintSettings.EndValue = toExpressionString;
            assemblyConstraint.DriveConstraintSettings.GoToStart();
            assemblyConstraint.DriveConstraintSettings.PlayForward();
        private static UnitsTypeEnum GetDataBaseUnitEnum(AssemblyConstraint assemblyConstraint)
            Inventor.UnitsTypeEnum dataBaseUnitEnum;
            if ((assemblyConstraint is Inventor.MateConstraint) || (assemblyConstraint is Inventor.FlushConstraint) ||
                (assemblyConstraint is Inventor.InsertConstraint) || (assemblyConstraint is Inventor.TangentConstraint))
                dataBaseUnitEnum = Inventor.UnitsTypeEnum.kDatabaseLengthUnits;
            else if (assemblyConstraint is Inventor.AngleConstraint)
                dataBaseUnitEnum = Inventor.UnitsTypeEnum.kDatabaseAngleUnits;
            else
                throw new InstanceNotFoundException("Unknown constraint type");
            return dataBaseUnitEnum;
Windows 7 64 bit
You are not logged in.
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
