Drawing view suppression rule
2 REPLIES 2
fishernow
432 Views, 2 Replies
Hi everyone,
I am stuck trying to find a way to suppress drawing views and drawing sheets. I have a model that consists of several parts and with ilogic in the model, I can suppress the components if i don't need them and that's all good. My drawing consists of several sheets with several views, the suppressed parts are remaining active even though the parts are suppressed in the model.
Q1- Why are the views not turned off or suppressed with the model part suppression?
Q2- When I try to use ilogic to suppress a view or the sheets I get the errors below.
Drawing view suppression rule:
If Parameter("105088 Shelves & Dividers Assembly.iam.s2sp2") = 0 Then
ActiveSheet.View("VIEW12") = False
End If
Rule Compile Errors in viewoff, in 105088 Shelves & Dividers Assembly.idw
Error on Line 2 : Property 'View' is 'ReadOnly'.
Sheet suppression rule:
ActiveSheet = ThisDrawing.Sheet("Sheet DP Shelf 1&2 :2") = False
End If
Error on Line 2 : Operator '=' is not defined for types 'Autodesk.iLogic.Interfaces.ICadDrawingSheet' and 'Boolean'.
Drawing parameter rule:
If Suppress_Sheets = True Then
ActiveSheet.View("VIEW1") = False
End If
Rule Compile Errors in Rule2, in 105088 Shelves & Dividers Assembly.idw
Eric
2 REPLIES 2
montylowe
in reply to: fishernow
Hey Eric any luck with this one???
MegaJerk
Use something like this:
ThisDrawing.Sheet("Sheet:2").View("Part1").View.Suppressed = False
Now if you’re throwing your representations on to a sheet (no matter if they are flat patterns or isometric who knows what) they will have a view name that you give them on creation. You can see what this view name is (AKA: View Identifier) when you double click on them (Right click à Edit View), and look at the bottom.
In the case above, I am looking at a View Identifier called Part1 on the sheet called Sheet.
Note that when you change the View name of your representation, you will need to update the rule to follow that!
Note 2: ALSO please look at the wording of the above code! See how it’s asking if the state is suppressed unlike how it states the suppressed (IsActive) state for the assembly. The above code is saying that it’s NOT suppressed.
If my solution worked or helped you out, please don't forget to hit the kudos button 🙂
iLogicCode Injector: goo.gl/uTT1IB
GitHub
