Inventor Programming - iLogic, Macros, AddIns & Apprentice
Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
Drawing dimension
4 REPLIES 4
marioriva
857 Views, 4 Replies
Drawing dimension
Good afternoon,
I need to recognize, via c#, the different types of dimensions (associated (A) or not (B)) as you can see in the attached image. Which is the property? "GeneralDimension.Attached" in my sample doesn't work. is the right property?
How can I do?
Thank you.
Mario
Tags (1)
4 REPLIES 4
GeneralDimension.Attached property is expected to indicate if the given dimension is orphaned or not. Could you upload the simplest dataset that reproduces your case?
Vladimir Ananyev
Developer Technical Services
Autodesk Developer Network
marioriva
in reply to: marioriva
My customize command:
- reads the files from directory and copy to another
- changes the values of xls reference
- changes the internal reference
- Updates views in drawing document
- saves the document
- runs the function checkOrphDimension to check and delete orphaned dimensions
I use this code:
        /// <summary>
        /// Delete orphaned quote
        /// </summary>
        /// <param name="dwg">drawing document</param>
        private void checkOrphDimension(Inventor._DrawingDocument dwg)
            try
                foreach (Sheet foglio in dwg.Sheets)
                    string nome_foglio = foglio.Name;
                    foreach (Inventor.GeneralDimension quota in foglio.DrawingDimensions.GeneralDimensions)
                       if (quota.Attached == false)
                           quota.Delete();
            catch (Exception ex)
                MessageBox.Show("Error: " + ex.ToString());
Attached you can find the drawing.
Mario
It seems that in this case checking the IntentOne or IntentTwo properties will be enough to identify sick dimensions.
If one of these properties produces error you may delete the dimension.
In your drawing I found three sick dimensions. Their model values are:
  • 140 mm
  • 630 mm
  • 867.807692307692 mm
Cheers,
Vladimir Ananyev
Thank you. It works.
My Orthodox way:
foreach (Inventor.LinearGeneralDimension quota in
try
Object entita;
entita = quota.IntentOne.Geometry;
quota.Delete();
Bye,
Mario
