Hey,
Has anyone Information where in witch Object is this Saved
Its Nothing to find in Dimension / Text
or Dimession Toolearance...
Thx for Help or Sugesstion
Mario
its Inventor 2014 / .net VB or vba or C#
Solved by philippe.leefsma. Go to Solution.
Did you have a look at the styles editor? Maybe you can give me an example?
Those are the inspection dimension data, you need to retrieve that info using GetInspectionDimensionData method:
Dim oApp As Inventor.Application Set oApp = ThisApplication Dim oDoc As Inventor.Document Set oDoc = oApp.ActiveEditDocument Dim dimension As GeneralDimension Set dimension = oDoc.SelectSet(1) Dim shape As InspectionDimensionShapeEnum Dim label As String Dim rate As String Call dimension.GetInspectionDimensionData(shape, label, rate)
