Inventor Programming - iLogic, Macros, AddIns & Apprentice
Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
_Document vs Document
2 REPLIES 2
noontz
717 Views, 2 Replies
Hi..  I´m a little insecure on this issue. Hope someone can straighten it out.
The eventhandler for ApplicationEvents.OnSaveDocument first parameter is of the type _Document
There is no search results in the help file ( nor this forum or related blogs ) for _Document except for an example on the use of DrawingViews.AddBaseView() where it also shows up as the first parameter.
Is _Document the exact same type as Document ? Changing the type to Document in the eventhandler compiles and works?  What´s the catch?? Is this a consistent naming convention throughout the API ( Is _Application the same as Application )
Just to elaborate on my confusion:  Do not use underscores, hyphens, or any other nonalphanumeric characters.
Some clarification would be most appreciated
2 REPLIES 2
adam.nagy
in reply to: noontz
If you look at the definition of each then it seems that _Document is the class and Document is the interface.
As you can see it's not Inventor specific as you can find similar things about Word: http://www.add-in-express.com/forum/read.php?FID=5&TID=3388
You should just use whatever is offered by Visua Studio when creating the event handler.
Cheers,
Adam Nagy
Autodesk Platform Services
noontz
in reply to: adam.nagy
Thanks alot for your reply Adam!
So if I understand this right Document is upcasted to _Document in the eventhandler & that´s why it works anyway.
Makes sense..  I just get a little nervous when unexposed ( and unexplained ) classes show up Smiley Wink
