Hi.. I´m a little insecure on this issue. Hope someone can straighten it out.
The eventhandler for ApplicationEvents.OnSaveDocument first parameter is of the type _Document
There is no search results in the help file ( nor this forum or related blogs ) for _Document except for an example on the use of DrawingViews.AddBaseView() where it also shows up as the first parameter.
Is _Document the exact same type as Document ? Changing the type to Document in the eventhandler compiles and works? What´s the catch?? Is this a consistent naming convention throughout the API ( Is _Application the same as Application )
Just to elaborate on my confusion: Do not use underscores, hyphens, or any other nonalphanumeric characters.
Some clarification would be most appreciated
Solved by adam.nagy. Go to Solution.
If you look at the definition of each then it seems that _Document is the class and Document is the interface.
As you can see it's not Inventor specific as you can find similar things about Word: http://www.add-in-express.com/forum/read.php?FID=5&TID=3388
You should just use whatever is offered by Visua Studio when creating the event handler.
Cheers,
Thanks alot for your reply Adam!
So if I understand this right Document is upcasted to _Document in the eventhandler & that´s why it works anyway.
Makes sense.. I just get a little nervous when unexposed ( and unexplained ) classes show up
