Inventor Customization
Message 1 of 4 (114 Views)
Accepted Solution
Divide a segment equally with a range in visual basic
114 Views, 3 Replies
01-15-2013 05:44 PM
How do you divide a segment equally with a range in visual basic?
example-
length is 144 in
range- 7.5 - 9in
answer- (18) at (range 8 in)
like to know how to do this in Visual Basic so I can create some rules and forms in iLogic
thx
Valued Contributor
jonbrabbs
Message 2 of 4 (107 Views)
Re: Divide a segment equally with a range in visual basic
01-15-2013 11:48 PM in reply to: heyjude19
Hi there,
There are loads of ways to do this. Here is one:
Sub Demo()
Dim Length As Double
Dim Range As Double
    Length = 144
    Range = 8
    MsgBox (Answer(Length, Range))
End Sub
Function Answer(L As Double, R As Double)
    Answer = L / R
End Function
This should be a start for you
Cheers
Jon.
If this post helps you, please give kudos.
Message 3 of 4 (100 Views)
01-16-2013 04:34 AM in reply to: jonbrabbs
Thanks Jon
- can this be done within the parameters instead of iLogic?
Valued Contributor
jonbrabbs
Message 4 of 4 (93 Views)
01-16-2013 06:55 AM in reply to: heyjude19
Yes, it's not difficult, but can be tricky and frustrating! Parameters can be pretty fickle when it comes to units.
If you have:
d0 = Length (in)
d1 = Range (in)
d2 = Answer/Segments (ul)
Note that the inch units cancel each other to give a unitless value (in/in = ul).
Cheers
Jon.
You are not logged in.
Announcements
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
Inventor Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Autodesk Inventor helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
