I am interested in using the ilogic interface to find out the Content Center path that was used to create a Content Center part. For example, I have a steel tube, 2"x2"x1/4", 6" long that came from Content Center. How do I find out (using code) the path that led to it ("Structural Shapes: Square/Rectangular Tubes: ..." etc.? I would think that this information is held somewhere within that part, since I can perform "Change Size" on it in an assembly and it brings up the correct Content Center destination.
Also, when placing a structural shape using code, how does one indicate how long that member should be?
Any guidance or suggestions related to this would be appreciated.
Dim InvDoc As Inventor.ApprenticeServerDocument
Dim InvApr As New Inventor.ApprenticeServerComponent
Dim FPath As String
InvDoc = InvApr.Open(FullPathtoFile)
InvDoc.ReferencedDocuments.Item(i).FullFileName 'To find the path of children of an assembly
FPath = InvDoc.FullFileName 'For a single component
This is based on .net and using apprentice so that Inventor does not need to be opened.
I believe you can do the same with
Dim InvDoc As Inventor.Document
Dim InvApr As New Inventor.InventorServer
but will open Inventor
ilogic looks like it will be similar, but I have never used it.
