"CVAengineering" <I
href="mailto:NoSpam@withheld.com">NoSpam@withheld.com> wrote in message
href="news:5785346@discussion.autodesk.com">news:5785346@discussion.autodesk.com...
used this code to make a new workplane which is offset from the XZ plane
by a distance of .2
How to determine what model parameter (name)
of .2?
Thx,
On Error Resume Next
Dim
oDoc As PartDocument
Set oDoc =
ThisApplication.ActiveDocument
Dim oOriginWP As
WorkPlane
Set oOriginWP =
oDoc.ComponentDefinition.WorkPlanes.Item("YZ Plane")
Dim oNewWP As WorkPlane
Set oNewWP =
oDoc.ComponentDefinition.WorkPlanes.Item("New
WorkPlane")
If Err
Then
Err.Clear
Else
Set oNewWP =
oDoc.ComponentDefinition.WorkPlanes.AddByPlaneAndOffset(oOriginWP, 0.2,
False)
oNewWP.Name = "New
WorkPlane"
href="http://www.CVAengineering.com">www.CVAengineering.com
IV11
Pro. sp2 and IV2008 Pro. sp1
Vault 2008 sp1
Window XP Pro
sp2
Pentium 3.2 Ghz, 3.0 GB of RAM
NVIDIA FX 3400
91.85
SpacePilot V 3.3.6
"brian r. iwaskewycz" <
href="mailto:biwaskewycz@REMOVETHIS.corefurnace.com">biwaskewycz@REMOVETHIS.corefurnace.com>
wrote in message
href="news:5785652@discussion.autodesk.com">news:5785652@discussion.autodesk.com...
oNewWP.Definition.Offset.Name
"CVAengineering" <I
message
by a distance of .2
of .2?
Thx,
Dim
Set oDoc =
Dim oOriginWP As
WorkPlane
Set oOriginWP =
Plane")
Dim oNewWP As
WorkPlane
Set oNewWP =
WorkPlane")
If Err
Then
Err.Clear
Else
Set oNewWP =
False)
oNewWP.Name = "New
WorkPlane"
IV11
Vault 2008 sp1
Window XP Pro
sp2
NVIDIA FX 3400
91.85
SpacePilot V 3.3.6
Hi Brian,
Do you know how I would be able to find function calls like the one you used here? If this post wasn't here there would be no way to figure out that there are more properties under the .Definition object. Is there a better way to use the object browser in VS?
-Thomas
