Hi Everyone,
Im using the code below to derive my assembly to a single part and then save that as a STEP file. However i have run into a few difficulties.
1) For some reason the derivied part includes any suppressed components when it is created. is there an option to prevent this?
2) Is there a way to have the File Name different to the original file name? for example i would like to save the .stp file as the iProperties "Part Number". I have played around with this and can't seem to get it to work.
Any Help is appreciated.
Dan
'set a reference to the assembly component definintion. 'this assumes an assembly document is open. Dim oAsmCompDef As AssemblyComponentDefinition oAsmCompDef = ThisApplication.ActiveDocument.ComponentDefinition 'define the path and file name Dim sPathandName as String sPathandName = ThisDoc.PathAndFileName(False) ' Create a new part file to derive the selected part into 'note: kPartDocumentObject is the default template 'you could specifiy a path and file name for a custom template Dim oPartDoc As PartDocument oPartDoc = ThisApplication.Documents.Add(kPartDocumentObject, ThisApplication.FileManager.GetTemplateFile(kPartDocumentObject)) 'create the derived assembly deffinition Dim oDerivedAssemblyDef As DerivedAssemblyDefinition oDerivedAssemblyDef = oPartDoc.ComponentDefinition.ReferenceComponents.DerivedAssemblyComponents.CreateDefinition(sPathandName & ".iam") 'Set derive style options oDerivedAssemblyDef.DeriveStyle = DerivedComponentStyleEnum.kDeriveAsSingleBodyWithSeams 'options: 'kDeriveAsSingleBodyWithSeams 'kDeriveAsSingleBodyNoSeams 'kDeriveAsMultipleBodies 'kDeriveAsWorkSurface 'Create the derived part Dim oDerivedAssembly As DerivedAssemblyComponent oDerivedAssembly = oPartDoc.ComponentDefinition.ReferenceComponents.DerivedAssemblyComponents.Add(oDerivedAssemblyDef) '- - - - - - - - - - - - - - - - save *.stp file- - - - - - - - - - - - - - - - - - - - - - - - - - - ' Get the STEP translator Add-In. Dim oSTEPTranslator As TranslatorAddIn oSTEPTranslator = ThisApplication.ApplicationAddIns.ItemById("{90AF7F40-0C01-11D5-8E83-0010B541CD80}") Dim oContext As TranslationContext oContext = ThisApplication.TransientObjects.CreateTranslationContext Dim oOptions As NameValueMap oOptions = ThisApplication.TransientObjects.CreateNameValueMap If oSTEPTranslator.HasSaveCopyAsOptions(ThisApplication.ActiveDocument, oContext, oOptions) Then ' Set application protocol. ' 2 = AP 203 - Configuration Controlled Design ' 3 = AP 214 - Automotive Design oOptions.Value("ApplicationProtocolType") = 3 ' Other options... 'oOptions.Value("Author") = "" 'oOptions.Value("Authorization") = "" 'oOptions.Value("Description") = "" 'oOptions.Value("Organization") = "" oContext.Type = IOMechanismEnum.kFileBrowseIOMechanism Dim oData As DataMedium oData = ThisApplication.TransientObjects.CreateDataMedium oData.FileName = sPathandName & ".stp" oSTEPTranslator.SaveCopyAs(ThisApplication.ActiveDocument, oContext, oOptions, oData) End If '- - - - - - - - - - - - end of *.stp file code - - - - - - - - - - - - - - - - - - - - - - - - - 'close the derived part without saving oPartDoc.Close(True) 'True set's the skipsave boolean variant MessageBox.Show("STP file created: " & sPathandName & ".stp", "iLogic")
Okay, Did a little more digging and have come up with a solution for the renaming problem.
'set a reference to the assembly component definintion.'this assumes an assembly document is open.Dim oAsmCompDef As AssemblyComponentDefinition oAsmCompDef = ThisApplication.ActiveDocument.ComponentDefinition 'define the path and file nameDim sPathandName As String sPathandName = ThisDoc.PathAndFileName(False) ' Create a new part file to derive the selected part into 'note: kPartDocumentObject is the default template'you could specifiy a path and file name for a custom templateDim oPartDoc As PartDocument oPartDoc = ThisApplication.Documents.Add(kPartDocumentObject, ThisApplication.FileManager.GetTemplateFile(kPartDocumentObject)) 'create the derived assembly deffinitionDim oDerivedAssemblyDef As DerivedAssemblyDefinition oDerivedAssemblyDef = oPartDoc.ComponentDefinition.ReferenceComponents.DerivedAssemblyComponents.CreateDefinition(sPathandName & ".iam") 'Set derive style optionsoDerivedAssemblyDef.DeriveStyle = DerivedComponentStyleEnum.kDeriveAsSingleBodyNoSeams 'options: 'kDeriveAsSingleBodyWithSeams 'kDeriveAsSingleBodyNoSeams 'kDeriveAsMultipleBodies 'kDeriveAsWorkSurface 'Create the derived partDim oDerivedAssembly As DerivedAssemblyComponent oDerivedAssembly = oPartDoc.ComponentDefinition.ReferenceComponents.DerivedAssemblyComponents.Add(oDerivedAssemblyDef) '- - - - - - - - - - - - - - - - save *.stp file- - - - - - - - - - - - - - - - - - - - - - - - - - - 'define the model referenced by the drawingDim oModelDoc = ThisDoc.ModelDocument ' Get the STEP translator Add-In.Dim oSTEPTranslator As TranslatorAddIn oSTEPTranslator = ThisApplication.ApplicationAddIns.ItemById("{90AF7F40-0C01-11D5-8E83-0010B541CD80}") Dim oContext As TranslationContext oContext = ThisApplication.TransientObjects.CreateTranslationContext Dim oOptions As NameValueMap oOptions = ThisApplication.TransientObjects.CreateNameValueMap If oSTEPTranslator.HasSaveCopyAsOptions(oModelDoc, oContext, oOptions) Then 'Options for STEP outputoOptions.Value("ApplicationProtocolType") = 3 'Set application protocol: 2 = AP 203 - Configuration Controlled Design, 3 = AP 214 - Automotive DesignoOptions.Value("Author") = ThisApplication.GeneralOptions.UserName oOptions.Value("Description") = iProperties.Value("Summary", "Title") oOptions.Value("Organization") = "IKM Technique AS" oContext.Type = IOMechanismEnum.kFileBrowseIOMechanism Dim oData As DataMedium oData = ThisApplication.TransientObjects.CreateDataMedium FilePath= ThisDoc.Path 'pathOutputPath = FilePath & "\" & "CREATED CYLINDER ASSEMBLIES" 'Output destination for the new STPOutputFileName = iProperties.Value("Project", "Part Number") & ".stp" 'Output File Name as specified in Custom iProperties, as specified by the iLogic rule OutputFileName 'Set the destination path & file nameoData.FileName = OutputPath & "\" & OutputFileName 'Publish DocumentoSTEPTranslator.SaveCopyAs(oModelDoc, oContext, oOptions, oData) End If '- - - - - - - - - - - - end of *.stp file code - - - - - - - - - - - - - - - - - - - - - - - - - 'close the derived part without savingoPartDoc.Close(True) 'True set's the skipsave boolean variantMessageBox.Show("STP file created: " & OutputFileName & ".stp", "iLogic")
Hi Dan,
If the option is not available in the UI then it's probably not in the API either.
You can check all the options available as shown here:
I could not reproduce the issue of seeing a suppressed component of a derived part show up in the exported SAT file.
Could you provide a non-confidential set of files that can be used to reproduce the issue?
Cheers,
Adam,
Thanks for your reply.
Turns out i had mixed some of the code up, i was saving the main assembly as a STEP rather than the new derived part..
Dan
