I have a code that'll print my dwgs to pdf. I created a form so that I can change a custom parameter called "SAVELOC" to direct where to save the pdf file. I really don't like this way of doing it. I was wondering if there is maybe a way to pull up a browser either through code or the form so that I can just click and point to the folder I want it to save to.
Here is my code...like I said, where it says "SAVELOC" it substitutes the entire folder path.
oPath = ThisDoc.Path
oFileName = ThisDoc.FileName(False) 'without extension
oRevNum = iProperties.Value("Project", "Revision Number")
oPDFAddIn = ThisApplication.ApplicationAddIns.ItemById _
("{0AC6FD96-2F4D-42CE-8BE0-8AEA580399E4}")
oDocument = ThisApplication.ActiveDocument
oContext = ThisApplication.TransientObjects.CreateTranslationContext
oContext.Type = IOMechanismEnum.kFileBrowseIOMechanism
oOptions = ThisApplication.TransientObjects.CreateNameValueMap
oDataMedium = ThisApplication.TransientObjects.CreateDataMedium
If oPDFAddIn.HasSaveCopyAsOptions(oDataMedium, oContext, oOptions) Then
oOptions.Value("All_Color_AS_Black") = 0
oOptions.Value("Remove_Line_Weights") = 0
oOptions.Value("Vector_Resolution") = 600
oOptions.Value("Sheet_Range") = Inventor.PrintRangeEnum.kPrintAllSheets
'oOptions.Value("Custom_Begin_Sheet") = 2
'oOptions.Value("Custom_End_Sheet") = 4
End If
'get PDF target folder path
oFolder = Left(oPath, InStrRev(oPath, SAVELOC)) & SAVELOC
'Check for the PDF folder and create it if it does not exist
If Not System.IO.Directory.Exists(oFolder) Then
System.IO.Directory.CreateDirectory(oFolder)
End If
'Set the PDF target file name
oDataMedium.FileName = oFolder & "\" & oFileName &".pdf"
'Publish document
oPDFAddIn.SaveCopyAs(oDocument, oContext, oOptions, oDataMedium)
Ben, Look for the "File Dialog API Sample" in the API Help. There is an example of opening the Open/Save Dialog.
Rob.
Here is how i do: Open folder where will be your pdf's. Copy address. Run this code. Change path in code.
response = MessageBox.Show("Did you change path in this rule?", "Reminder",MessageBoxButtons.YesNo)
If response = vbNo Then Exit Sub
'Save PDF with options
'SaveLoc = "C:\"
'FileName = ThisDoc.FileName(True)
'ThisDoc.Document.SaveAs(FileName & (".pdf") , True)
PN = iProperties.Value("Project", "Part Number")
'path_and_namePDF = ThisDoc.Pathandname(False)
oPDFAddIn = ThisApplication.ApplicationAddIns.ItemById("{0AC6FD96-2F4D-42CE-8BE0-8AEA580399E4}")
oOptions.Value("All_Color_AS_Black") = 1
oOptions.Value("Remove_Line_Weights") = 1
oOptions.Value("Vector_Resolution") = 400
'oOptions.Value("Custom_Begin_Sheet") = 1
End If
'Set the destination file name
oPath = "C:\MY PDF FILES\"
oPath = InputBox("Replace Path","New Path")
oDataMedium.FileName = oPath & "\" & PN & ".pdf"
'Publish document
'Confirmation message
MessageBox.Show("PDF SAVED TO: " & oDataMedium.FileName, "PDF Saved", MessageBoxButtons.OK)
On Error Goto handlePDFLock
'Publish document.
Call oPDFAddIn.SaveCopyAs(oDocument, oContext, oOptions, oDataMedium)
Exit Sub
handlePDFLock:
MessageBox.Show("PDF could not be saved, most likely someone else has it open", "No PDF for you " & ThisApplication.GeneralOptions.UserName & "!")
Resume Next
handleXLSLock:
MessageBox.Show("No XLS", "iLogic")
Resume Next
Yes, I believe the Open/Save Dialog is the key to my goal here, but I am only an ilogic beginner so it may take some time with a lot of trial and error for me to figure this out.
Thanks you guys for the great suggestions! I'll let you know if I get something
In this code i gave you just change path with desired path of yours pdf folder
run rule , and you will need to copy paste address where is your folder.
That is it , this one is very easy š and working very well. It is time saver
What I have is one master folder, and then in that folder I have a bunch of project folders, in those project folders I have assembly folders. I'm constantly mapping back and forth through folders saving pdfs in many different folders throughout the day. It's a great code you gave me and way better than what I was using but my goal is to pull up the folders in windows and navigate back and forth by clicking rather than typing. Thanks again for your replys!
