Inventor Customization
Active Contributor
sanjaysy
Message 1 of 5 (252 Views)
Customising Measure Tool
252 Views, 4 Replies
04-28-2006 04:19 AM
Whenever we use measure tool it will show the a dialog box with valves of x,y,z, delta X, delta Y & delta Z. I want to customize the same as per the attached image.
Customize this, dialog box will not disappear(modal) after entering into any other command so no need to remember the values of x,y....etc.
Sanjay Yallure
Inventor Professional 10.0
Sanjay
Distinguished Contributor
ADNpati
Message 2 of 5 (208 Views)
Re: Customising Measure Tool
11-07-2012 08:31 PM in reply to: sanjaysy
HEllo Sanjay,
Did you get that macro done, customising the measure tool???
I need a tool to measure from face to workpoint.
Can you please help me??
Amool.
Mechanical Engineer
Inventor Applications Engineer
If my solution seems to remedy your problem, please press the Accept Solution button, Some KUDOS -
ADN Support Specialist
adam.nagy
Message 3 of 5 (168 Views)
11-20-2012 08:19 AM in reply to: ADNpati
Inventor dialogs are not customizable in general. However you can create your own dialog if you want to.
The measure functionalities are available through the API, so that part of it you could reuse.
Adam Nagy
Developer Technical Services
Autodesk Developer Network
ADNpati
Message 4 of 5 (156 Views)
11-20-2012 02:07 PM in reply to: adam.nagy
HEllo Adam,
I am writing a macro to get distances of "WorkPoint"s in Occurrences from "Face"s of parts in occurrences.
And writing all data to excel file or csv file.
Thanks.
AD
Mechanical Engineer
xiaodong.liang
Message 5 of 5 (122 Views)
12-18-2012 12:18 AM in reply to: ADNpati
well, WorkPoint.Point has the method Point.DistanceTo to get the distance of two work points.
As to writting to Excel/CSV, you can just use Windows API. Searching with the keywords, you could also find some posts here.
Xiaodong Liang
You are not logged in.
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
