Inventor Customization
Valued Contributor
LSA-skan
Message 11 of 16 (301 Views)
Re: Custom Property Format in iLogic
02-05-2013 06:26 AM in reply to: gary.belisle
Hi Gary
thanks.. !! I will try with this.. :smileyhappy:
Regarding the Sheetmatal parameters... then my thought is, that if i can do it manually, then i should also be able to do it with an iLogic rule..?? but as mentioned, im not a pro with this.. :smileyhappy:
/LSA-Skan
Valued Contributor
gary.belisle
Message 12 of 16 (298 Views)
02-05-2013 06:56 AM in reply to: LSA-skan
Glad to help. I'd investigate the code but I can't commit the time right now. What I've done is set up User Parameters to drive the sheet metal parameters. For example I drive thickness with a User Parameters named "Thickness" but you have to disable the sheet metal default checkbox "Use Thickness from Rule" to do that.
i7-2720QM Dell Precision M6600, Win 7 Pro 64-bit, 8GB RAM
Autodesk Product Design Suite Ultimate 2013
Autodesk Vault Professional 2013
Valued Contributor
LSA-skan
Message 13 of 16 (295 Views)
02-05-2013 07:11 AM in reply to: gary.belisle
All good..! thanks for the effort.. i will give you a Kudos for your help :smileyhappy:
Distinguished Contributor
wseaston
Message 14 of 16 (264 Views)
05-03-2013 05:47 AM in reply to: gary.belisle
Hi My requirment is slightly different so I hope someone can provide me with some assistance please.
I need to change the custom property format for a single specified fx parameter (<G_L>) as created by Inventor Frame generator, so that it drops the "mm" units and the trailing zero's.
The trickier part is that I would like to run an iLogic rule from the assembly level so that the custom property changes are made to the "<G_L>" fx parameter in all the parts in the assembly.
Wayne
wseaston
Message 15 of 16 (247 Views)
05-09-2013 01:36 AM in reply to: gary.belisle
Please help.
I have tried to use this iLogic code but am getting the following error code:
Rule Compile Errors in Rule4, in Part1
Error on Line 5 : 'For' must end with a matching 'Next'.
Error on Line 15 : 'NextoParameter' is not declared. It may be inaccessible due to its protection level.
Please can someone suggest a solution.
Valued Contributor
gary.belisle
Message 16 of 16 (241 Views)
05-09-2013 05:43 AM in reply to: wseaston
Try adding a space between "Next" and "oParameter" in "NextoParameter"
You are not logged in.
Announcements
Need installation help?
Ask the Community
Inventor Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Autodesk Inventor helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
