Inventor Programming - iLogic, Macros, AddIns & Apprentice
Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
Creating Base View in idw
7 REPLIES 7
Message 1 of 8
paulschuepbach
529 Views, 7 Replies
Hi folks, I have a AssemblyDoc open and I want to create a dawing automatically. Therefor I create a new idw, using the default template. The I want to add a BaseView to the drawing. This all works fine, except when I want to create this BaseView using 'kCurrentViewOrientation' enum - it creates a FronView ???? The other orientation-enum's work fine. Is this a bug ? Any idea for a workaround ?
Best, Paul
7 REPLIES 7
Message 2 of 8
in reply to: paulschuepbach
I don't have an answer for your question, because I
am stuck at step 1: creating the base view itself.
The Helpfile is not of much help, not 1 clear
example.
I have this code (in de IDW), but I don't know how
to set the model (c:\test.ipt) as a document.
What should I change?
Sub PlaceBaseView()
Dim oDoc As DrawingDocument
Set oDoc =
ThisApplication.ActiveDocument
Dim oTransGeom As TransientGeometry
Set
oTransGeom = ThisApplication.TransientGeometry
Dim oCoord1 As Point2d
Set oCoord1 =
oTransGeom.CreatePoint2d(0, 0)
Dim oModel As Document
Set oModel = Nothing
'<=== What should this be???
Dim oScale As Double
oScale = 0.2
Dim oDrawView As DrawingView
Set oDrawView =
oDoc.ActiveSheet.DrawingViews.AddBaseView(oModel,oCoord1,oScale,kCurrentViewOrientation,kHiddenLineRemovedDrawingViewStyle,,,,)
'<=== Is this correct???
End Sub
style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
Hi
workaround ?
Best, Paul
Message 3 of 8
Burnit87
Message 4 of 8
NachitoMax
Hi
If it helps, I have nearly finished an addin that completely manages drawing views. With the tool you can-
Select the views you want on the sheet
Create a new drawing file for the active assembly
Create a new drawing file for each part in the assembly
Choose between drawing view and job pack view
Set the scale
Select between the view styles
Add the correct label text (front elevation and scale)
Create drawing files for selected parts in the assembly
Preview each part as it is clicked in a viewer
A few more days on the addin then it will be ready for the App Store.
Nigel
Nacho
Automation & Design Engineer
Inventor Programmer (C#, VB.Net / iLogic)
Message 5 of 8
Carthik_Babu
hi,
u need to copy the code in part file for creation of automatic drawing views.
check the below link.....
http://forums.autodesk.com/t5/Inventor-Customization/Automated-DWG/m-p/4648777#M47390
download test auto.ipt, it has useful codes to automate the drafting process.
Carthik Babu M.S, Asst Manager - Machine Building,
Gabriel India Ltd,Hosur, TN, INDIA
Email:carthik_ms@yahoo.co.in ,
https://grabcad.com/carthik-1/projects
"May all beings be happy" http://www.dhamma.org/
Message 6 of 8
NachitoMax
in reply to: Carthik_Babu
Hi
thanks for the reply. i downloaded the ipt but there isnt any code inside. i looked via the vba editor
Please advise
Nigel
Nacho
Message 7 of 8
Hi, kindly check the code in Ilogic editor or paste my code (which is available in the previous link) in your ipt file Ilogic editor and check
Message 8 of 8
Burnit87
im using this code to create a flat pattern on a new drawing including scaling and stuff
i hope it is of some help
Dim ActivIdw AsDrawingDocument = m_InvApp.ActiveDocument
Dim oSheet AsSheet = ActivIdw.ActiveSheet
Dim BsVwScale AsDouble
Dim prtProterty AsPropertySet = prtDoc.PropertySets.Item("{D5CDD505-2E9C-101B-9397-08002B2CF9AE}")
Dim prtWidth, prtLength AsDouble
prtLength = prtDoc.PropertySets.Item("Design Tracking Properties").Item("Flat Pattern Length").Value
prtWidth = prtDoc.PropertySets.Item("Design Tracking Properties").Item("Flat Pattern Width").Value
If prtWidth > prtLength Then
BsVwScale = Math.Round(1 / ((oSheet.Width - 20) / prtWidth), 2)
Else
BsVwScale = Math.Round(1 / ((oSheet.Width - 20) / prtLength), 2)
EndIf
SelectCase BsVwScale
CaseIs < 0.2
BsVwScale = 5
CaseIs < 0.5
BsVwScale = 2
CaseIs <= 1
BsVwScale = 1
CaseIs < 2.5
BsVwScale = 0.4
CaseIs < 5
BsVwScale = 0.2
CaseIs < 10
BsVwScale = 0.1
CaseIs < 25
BsVwScale = 0.04
CaseIs < 50
BsVwScale = 0.02
CaseIs < 100
BsVwScale = 0.01
EndSelect
Dim oViewPos AsPoint2d = m_InvApp.TransientGeometry.CreatePoint2d(oSheet.Width / 2, oSheet.Height / 2)
Dim prtDocBaseView AsDrawingView
Dim oOptions AsNameValueMap = m_InvApp.TransientObjects.CreateNameValueMap
Call oOptions.Add("SheetMetalFoldedModel", False)
prtDocBaseView = oSheet.DrawingViews.AddBaseView(PrtToInsert, oViewPos, BsVwScale, ViewOrientationTypeEnum.kDefaultViewOrientation, DrawingViewStyleEnum.kHiddenLineDrawingViewStyle, , , oOptions)
prtDocBaseView.DisplayThreadFeatures = False
BP
