Good Morning all!
To make my drawing notes here, I'm with other idea now, maybe easier:
With iLogic, define some pre notes and when the user choose one option some notes are chosen too.
The idea now is: Create a text direct inside on Sketched Symbol OR edit some textfields inside the Symbol.
The symbol could be one existent, so its not necessary to create it.
I got a code to create the text, and that works perfectly! Just what im trying now is create this text into the Symbol... I've tried many ways with reference from:
but i didnt found a solution for it, how could I make it then guys ?
The code to create the tet im usnig is this one:
' a reference to the drawing document. ' This assumes a drawing document is active. Dim oDrawDoc As DrawingDocument oDrawDoc = ThisApplication.ActiveDocument ' a reference to the active sheet. Dim oActiveSheet As Sheet oActiveSheet = oDrawDoc.ActiveSheet ' a reference to the GeneralNotes object Dim oGeneralNotes As GeneralNotes oGeneralNotes = oActiveSheet.DrawingNotes.GeneralNotes Dim oTG As TransientGeometry oTG = ThisApplication.TransientGeometry ' Create text with simple string as input. Since this doesn't use ' any text overrides, it will default to the active text style. Dim sText As String sText = "NOTAS" Dim oGeneralNote As GeneralNote oGeneralNote = oGeneralNotes.AddFitted(oTG.CreatePoint2d(3, 16), sText) Dim dYCoord As Double dYCoord = 14 Dim dYOff As Double Dim oStyle As TextStyle oStyle = oGeneralNotes.Item(1).TextStyle dYOff = oStyle.FontSize * 1 '1º Nota sText = "1) This is note 1" & vbCrLf & "segunda linha" & vbCrLf & "terceira linha." oGeneralNote = oGeneralNotes.AddFitted(oTG.CreatePoint2d(4, dYCoord), sText) '2º Nota dYCoord = dYCoord - (oGeneralNote.FittedTextHeight + 0.2) sText = "2) teste" oGeneralNote = oGeneralNotes.AddFitted(oTG.CreatePoint2d(4, dYCoord), sText)
but, if i could just edit one existent text filed into the symbol would be great too 🙂
and one "extra doubt", in all the codes that i get here, i have to erase the "public sub" and the "set" from all code, am I doing something wrong ? I'm running directly from the iLogic window.
Túlio Barata
Solved by tuliobarata. Go to Solution.
Hi all!
I almost finished the code, just new now to know how to put the text it creates into a symbol :).
It gives me a little of work creating parameters and conditions, actually dunno if there is a easier way, but the result is nice and usefull here 🙂
Its basiclly one form that you can choose if wanna use 2 languages, 5 types of predefined notes and some custom.
follow the code:
'Idioma para os titulosDim Tit_ID1,Tit_ID2 As String 'INICIO - Seleção de idiomato para os titulosSelect Case ref_ID1 Case "EN" Tit_ID1 = "NOTES:" Case "ES" Tit_ID1 = "NOTAS:" Case "FR" Tit_ID1 = "NOTES:" Case "PT" Tit_ID1 = "NOTAS:" End Select Select Case ref_ID2 Case "EN" Tit_ID2 = "NOTES:" Case "ES" Tit_ID2 = "NOTAS:" Case "FR" Tit_ID2 = "NOTES:" Case "PT" Tit_ID2 = "NOTAS:" End Select 'FIM - Seleção de idiomato para os titulos 'INICIO - Verificação se ha necessidade de um idioma secundarioIf ref_ID2 = "0 - Sem idioma secundario" Then ref_ID = False Else ref_ID = True End If 'FIM - Varificação se ha necessidade de um idioma secundario 'INICIO - Seleção do conteudo de cada linha da nota com 2 idiomasSelect Case ref_Nota Case "0 - Notas em branco" '----------------------------------------------------------------------------------------------------------------------- Case "1 - Notas para montagens gerais" Select Case ref_ID1 Case "EN" Nota1_ID1 = "01) TO MANUFACTURE= " & qtd_itens & " ASSEMBLY(IES)." Nota2_ID1 = "02) BILL OF MATERIALS FOR 01 ASSEMBLY." Nota3_ID1 = "03) DIMENSIONS IN mm, EXCEPT WHERE INDICATED." Case "ES" Case "FR" Case "PT" Nota1_ID1 = "01) CONFECCIONAR= " & qtd_itens & " CONJUNTO(S)." Nota2_ID1 = "02) LISTA DE MATERIAL PARA 01 CONJUNTO." Nota3_ID1 = "03) DIMENSÕES EM mm, EXCETO ONDE INDICADO." End Select Select Case ref_ID2 Case "EN" Nota1_ID2 = "01) TO MANUFACTURE= " & qtd_itens & " ASSEMBLY(IES)." Nota2_ID2 = "02) BILL OF MATERIALS FOR 01 ASSEMBLY." Nota3_ID2 = "03) DIMENSIONS IN mm, EXCEPT WHERE INDICATED." Case "ES" Case "FR" Case "PT" Nota1_ID2 = "01) CONFECCIONAR= " & qtd_itens & " CONJUNTO(S)." Nota2_ID2 = "02) LISTA DE MATERIAL PARA 01 CONJUNTO." Nota3_ID2 = "03) DIMENSÕES EM mm, EXCETO ONDE INDICADO." End Select '----------------------------------------------------------------------------------------------------------------------- Case "2 - Submontagens SEM det. de usinagem" Select Case ref_ID1 Case "EN" Nota1_ID1 = "01) TO MANUFACTURE= " & qtd_itens & " ASSEMBLY(IES) PER EQUIPMENT." Nota2_ID1 = "02) BILL OF MATERIALS FOR 01 ASSEMBLY." Nota3_ID1 = "03) DIMENSIONS IN mm, EXCEPT WHERE INDICATED." Case "ES" Case "FR" Case "PT" Nota1_ID1 = "01) CONFECCIONAR= " & qtd_itens & " CONJUNTO(S) POR EQUIPAMENTO." Nota2_ID1 = "02) LISTA DE MATERIAL PARA 01 CONJUNTO." Nota3_ID1 = "03) DIMENSÕES EM mm, EXCETO ONDE INDICADO." End Select Select Case ref_ID2 Case "EN" Nota1_ID2 = "01) TO MANUFACTURE= " & qtd_itens & " ASSEMBLY(IES) PER EQUIPMENT." Nota2_ID2 = "02) BILL OF MATERIALS FOR 01 ASSEMBLY." Nota3_ID2 = "03) DIMENSIONS IN mm, EXCEPT WHERE INDICATED." Case "ES" Case "FR" Case "PT" Nota1_ID2 = "01) CONFECCIONAR= " & qtd_itens & " CONJUNTO(S) POR EQUIPAMENTO." Nota2_ID2 = "02) LISTA DE MATERIAL PARA 01 CONJUNTO." Nota3_ID2 = "03) DIMENSÕES EM mm, EXCETO ONDE INDICADO." End Select '----------------------------------------------------------------------------------------------------------------------- Case "3 - Submontagens COM det. de usinagem" End Select 'FIM - Seleção do conteudo de cada linha da nota com 2 idiomas 'INICIO - Criação dos textos 'coordenadas e espaçamentos Dim dYCoord,dXCoord,dXCoord_,dY00,dY11,dY12 As Double 'coordenada inicial de posicionamento em Y dYCoord = -5 'coordenada inicial de posicionamento em X dXCoord = 0 'deslocamento em X das notas no idioma secundario dXCoord_ = dXCoord+0 'espaçamento inicial entre o titulo e a primeira linha da nota dY00 = 0.3 'espaçamento entre as linhas do idioma primario dY11 = 0.2 'espaçamento entre as linhas do idioma secundario dY12 = 0.05 ' a reference to the drawing document. ' This assumes a drawing document is active. Dim oDrawDoc As DrawingDocument oDrawDoc = ThisApplication.ActiveDocument ' a reference to the active sheet. Dim oActiveSheet As Sheet oActiveSheet = oDrawDoc.ActiveSheet ' a reference to the GeneralNotes object Dim oGeneralNotes As GeneralNotes oGeneralNotes = oActiveSheet.DrawingNotes.GeneralNotes Dim oTG As TransientGeometry oTG = ThisApplication.TransientGeometry ' Create text with simple string as input. Since this doesn't use ' any text overrides, it will default to the active text style. Dim oGeneralNote As GeneralNote '----------------------------------------------------------------------------------------------------------------------- 'Titulo ID1 oGeneralNote = oGeneralNotes.AddFitted(oTG.CreatePoint2d(dXCoord, dYCoord), Tit_ID1,"COMUMT3") 'Titulo ID2 If ref_ID = True Then dYCoord = dYCoord - (oGeneralNote.FittedTextHeight + dY12) oGeneralNote = oGeneralNotes.AddFitted(oTG.CreatePoint2d(dXCoord_, dYCoord), Tit_ID2,"NOTA_L2") End If '----------------------------------------------------------------------------------------------------------------------- '1º Nota ID1 dYCoord = dYCoord - (oGeneralNote.FittedTextHeight + dY00) oGeneralNote = oGeneralNotes.AddFitted(oTG.CreatePoint2d(dXCoord, dYCoord), Nota1_ID1,"NOTA_L1") '1º Nota ID2 If ref_ID = True Then dYCoord = dYCoord - (oGeneralNote.FittedTextHeight + dY12) oGeneralNote = oGeneralNotes.AddFitted(oTG.CreatePoint2d(dXCoord_, dYCoord), Nota1_ID2,"NOTA_L2") End If '----------------------------------------------------------------------------------------------------------------------- '2º Nota ID1 dYCoord = dYCoord - (oGeneralNote.FittedTextHeight + dY11) oGeneralNote = oGeneralNotes.AddFitted(oTG.CreatePoint2d(dXCoord, dYCoord), Nota2_ID1,"NOTA_L1") '2º Nota ID2 If ref_ID = True Then dYCoord = dYCoord - (oGeneralNote.FittedTextHeight + dY12) oGeneralNote = oGeneralNotes.AddFitted(oTG.CreatePoint2d(dXCoord_, dYCoord), Nota2_ID2,"NOTA_L2") End If '----------------------------------------------------------------------------------------------------------------------- '3º Nota ID1 dYCoord = dYCoord - (oGeneralNote.FittedTextHeight + dY11) oGeneralNote = oGeneralNotes.AddFitted(oTG.CreatePoint2d(dXCoord, dYCoord), Nota3_ID1,"NOTA_L1") '3º Nota ID2 If ref_ID = True Then dYCoord = dYCoord - (oGeneralNote.FittedTextHeight + dY12) oGeneralNote = oGeneralNotes.AddFitted(oTG.CreatePoint2d(dXCoord_, dYCoord), Nota3_ID2,"NOTA_L2") End If '----------------------------------------------------------------------------------------------------------------------- '4º Nota ID1 dYCoord = dYCoord - (oGeneralNote.FittedTextHeight + dY11) oGeneralNote = oGeneralNotes.AddFitted(oTG.CreatePoint2d(dXCoord, dYCoord), Nota4_ID1,"NOTA_L1") '4º Nota ID2 If ref_ID = True Then dYCoord = dYCoord - (oGeneralNote.FittedTextHeight + dY12) oGeneralNote = oGeneralNotes.AddFitted(oTG.CreatePoint2d(dXCoord_, dYCoord), Nota4_ID2,"NOTA_L2") End If '----------------------------------------------------------------------------------------------------------------------- '5º Nota ID1 dYCoord = dYCoord - (oGeneralNote.FittedTextHeight + dY11) oGeneralNote = oGeneralNotes.AddFitted(oTG.CreatePoint2d(dXCoord, dYCoord), Nota5_ID1,"NOTA_L1") '5º Nota ID2 If ref_ID = True Then dYCoord = dYCoord - (oGeneralNote.FittedTextHeight + dY12) oGeneralNote = oGeneralNotes.AddFitted(oTG.CreatePoint2d(dXCoord_, dYCoord), Nota5_ID2,"NOTA_L2") End If '-----------------------------------------------------------------------------------------------------------------------
Well, if someone knows how to put it into a symbol, plz tell me 😄
Thanks all!
Túlio Barata
Hi again!
Sry for answering again to my own post, but with some tries on weekend now I can edit one existent symbol. With the code below I verify if the symbol is already inserted in the sheet, and if yes it delete the symbol, then insert again.
The problem now is how to put my code to create those notes, inside this symbol insertion.
Should i change any code, like the GeneralNotes for something of SketchedSymbols ? I tried by some ways here, but in all of then i got errors.
One detail that i didnt put in this code, is to verify if the symbol is already created or not..I'm using one symbol that i created manually.
The code that im using to insert the symbol:
Dim oDrawDoc As DrawingDocument oDrawDoc = ThisApplication.ActiveDocument 'Update the document oDrawDoc.Update Dim oSheets As Sheets oSheets = oDrawDoc.Sheets Dim oSheet As Sheet Dim oViews As DrawingViews Dim oView As DrawingView Dim oSymbol As SketchedSymbol Dim oSymbols As SketchedSymbols 'iterate through all of the sheetsFor Each oSheet In oSheets 'remove existing sketched symbols named View Label For Each oSymbol In oSheet.SketchedSymbols If oSymbol.Definition.Name = "Notas" Then oSymbol.Delete Else End If Next Next ' Set a reference to the drawing document. ' This assumes a drawing document is active. ' Create the new sketched symbol definition. Dim oSketchedSymbolDef As SketchedSymbolDefinition oSketchedSymbolDef = oDrawDoc.SketchedSymbolDefinitions("Notas") ' Open the sketched symbol definition's sketch for edit. This is done by calling the Edit ' method of the SketchedSymbolDefinition to obtain a DrawingSketch. This actually creates ' a copy of the sketched symbol definition's and opens it for edit. Dim oSketch As DrawingSketch Call oSketchedSymbolDef.Edit(oSketch) 'HERE I SHOUL PUT MY CODE TO CREATE THE TEXT, BUT ISNT WORKING USING THE CODE FROM OTHER POST. Call oSketchedSymbolDef.ExitEdit(True) 'Set a reference to the active sheet. Dim oDrgSheet As Sheet oDrgSheet = oDrawDoc.ActiveSheet ' Set a reference to the sheet's border Dim oBorder As Border oBorder = oDrgSheet.Border Dim oPlacementPoint As Point2d If Not oBorder Is Nothing Then ' A border exists. The placement point ' is the top-right corner of the border. oPlacementPoint = oBorder.RangeBox.MaxPoint Else ' There is no border. The placement point ' is the top-right corner of the sheet. oPlacementPoint = ThisApplication.TransientGeometry.CreatePoint2d(oDrawDoc.Width, oDrawDoc.Height) End If ' Add an instance of the sketched symbol definition to the sheet. ' Rotate the instance by 0 degrees and scale by 1 when adding. ' The symbol will be inserted at the upper right corner of the sheet. Dim oSketchedSymbol As SketchedSymbol oSketchedSymbol = oDrgSheet.SketchedSymbols.Add(oSketchedSymbolDef, oPlacementPoint, (0), 1)
Now i guess the code is almost complete...almost :S
Thanks again!
Túlio Barata
The problem is that i was using GeneralNotes, i guess that doesnt work on Symbols, now im using TextBoxes as the code below and its working perfectly!
'Abre o symbol para edição
Dim oTextBox As TextBox
'1º Nota ID1dYCoord = dYCoord - (oTextBox.FittedTextHeight + dY00) If Not Nota1_ID1="" Then oTextBox = oSketch.TextBoxes.AddFitted(oTG.CreatePoint2d(dXCoord, dYCoord), Nota1_ID1,"NOTA_L1") End If '1º Nota ID2If ref_ID = True And Nota1_ID2 <> "" Then dYCoord = dYCoord - (oTextBox.FittedTextHeight + dY12) oTextBox = oSketch.TextBoxes.AddFitted(oTG.CreatePoint2d(dXCoord_, dYCoord), Nota1_ID2,"NOTA_L2") End If
Thanks!
Túlio Barata
