What is the code to create (or add) a new sheet in a drawing with iLogic?
Solved by fsanchou. Go to Solution.
I know that this is an older post but wanted to add something.
In Inventor 2014, when I click the "New Sheet" button under "Place Views", it inserts a sheet identical to the previous sheet - same size, border, and title block. The code above inserts a sheet but it's a default blank sheet that I then need to format as required. Is there a way for iLogic to mimic the "New Sheet" button?
You could have it temporarily create a new sheet format and then delete it, or just write a program to place everything in the same location.
