I am not sure if this can be done. I am trying to ILogic create external rule to create a pdf with multiple sheet to a specific location.
So far I have this setup (below) and it only needs to create all sheets, otherwise it works.
mfgFolder="P:\S_Works-Dwgs\X---\"&ThisDoc.FileName(False)
ThisDoc.Document.SaveAs(mfgFolder&ThisDoc.FileName&(".pdf") , True)
MessageBox.Show("PDF Saved", "File Save")
Can anyone help?
It's always worth checking things first in the UI. If it's possible there then it's quite likely possible through the API as well.
Have just found a blog post on this actually: http://modthemachine.typepad.com/my_weblog/2009/01/translating-files-with-the-api.html
Cheers,
