Inventor Customization
New Member
Message 1 of 2 (167 Views)
Create Mesh from Solid
167 Views, 1 Replies
10-17-2012 08:35 AM
I try to migrate our ObjectArx Api to Inventor. Therefore I need a function to create a mesh from a solid.
With Autocad .Net Api, I can use GetObjectMesh(DbObject obj, MeshFaceterData parameter). Does in the Inventor Api a similiar function exist?
In the parameters I need to set the deviation in the same way as in the Autocad .Net Api.
Example:
FaceterDevNormal = 0.1;
FaceterDevSurface = 0.1;
FaceterMeshType = 2;
Thanks for further help.
Markus
ADN Support Specialist
Message 2 of 2 (147 Views)
Re: Create Mesh from Solid
10-22-2012 12:18 AM in reply to: Markus67
Hi Markus,
There isn't a way to set the deviation similarly than in AutoCAD, but you need to use the "CalculateFacets" API where you can specify a tolerance. Below is a VBA sample, it can be used on SurfaceBody or Face objects, client graphics are used to visualize the result:
Public Sub GenerateFacets(facetable As Variant)
    Dim tolerance As Double
    Dim VertexCount As Long
    Dim FacetCount As Long
    Dim VertexCoords() As Double
    Dim normals() As Double
    Dim Indices() As Long
    tolerance = 0.003
    Call facetable.CalculateFacets(tolerance, VertexCount, FacetCount, VertexCoords, normals, Indices)
    Dim nbTriangles As Long
    nbTriangles = 0
    Dim i As Integer
    For i = 0 To UBound(Indices) Step 3
        Dim vIndex1 As Integer
        Dim vIndex2 As Integer
        Dim vIndex3 As Integer
        vIndex1 = (Indices(i) - 1) * 3
        vIndex2 = (Indices(i + 1) - 1) * 3
        vIndex3 = (Indices(i + 2) - 1) * 3
        Dim vertex1(2) As Double
        Dim vertex2(2) As Double
        Dim vertex3(2) As Double
        vertex1(0) = VertexCoords(vIndex1)
        vertex1(1) = VertexCoords(vIndex1 + 1)
        vertex1(2) = VertexCoords(vIndex1 + 2)
        vertex2(0) = VertexCoords(vIndex2)
        vertex2(1) = VertexCoords(vIndex2 + 1)
        vertex2(2) = VertexCoords(vIndex2 + 2)
        vertex3(0) = VertexCoords(vIndex3)
        vertex3(1) = VertexCoords(vIndex3 + 1)
        vertex3(2) = VertexCoords(vIndex3 + 2)
        'Call custom method to visualize facet edges
        Call DrawLineGraphics(vertex1, vertex2)
        Call DrawLineGraphics(vertex2, vertex3)
        Call DrawLineGraphics(vertex3, vertex1)
        nbTriangles = nbTriangles + 1
    Next
    ThisApplication.ActiveView.Update
End Sub
Public Sub DrawLineGraphics(startpt() As Double, endpt() As Double)
    Dim doc As Document
    Set doc = ThisApplication.ActiveDocument
    Dim compDef As ComponentDefinition
    Set compDef = doc.ComponentDefinition
    On Error Resume Next
    Dim dataSets As GraphicsDataSets
    Set dataSets = doc.GraphicsDataSetsCollection("LineGraphics")
    Dim clientGraphics As clientGraphics
    Set clientGraphics = compDef.ClientGraphicsCollection("LineGraphics")
    If Err Then
        Err.clear
        Set dataSets = doc.GraphicsDataSetsCollection.Add("LineGraphics")
        Set clientGraphics = compDef.ClientGraphicsCollection.Add("LineGraphics")
        Call dataSets.CreateCoordinateSet(1)
        Call clientGraphics.AddNode(1)
        Call clientGraphics(1).AddLineGraphics
    End If
    On Error GoTo 0
    Dim coordSet As GraphicsCoordinateSet
    Set coordSet = dataSets(1)
    Dim coords() As Double
    Call coordSet.GetCoordinates(coords)
    Dim idx As Long
    idx = 3 * coordSet.count
    ReDim Preserve coords(0 To idx + 5)
    coords(idx) = startpt(0)
    coords(idx + 1) = startpt(1)
    coords(idx + 2) = startpt(2)
    coords(idx + 3) = endpt(0)
    coords(idx + 4) = endpt(1)
    coords(idx + 5) = endpt(2)
    Call coordSet.PutCoordinates(coords)
    Dim lineGraphics As lineGraphics
    Set lineGraphics = clientGraphics(1).item(1)
    lineGraphics.CoordinateSet = coordSet
End Sub
Philippe.
Philippe Leefsma
Developer Technical Services
Autodesk Developer Network
You are not logged in.
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
