I try to migrate our ObjectArx Api to Inventor. Therefore I need a function to create a mesh from a solid.
With Autocad .Net Api, I can use GetObjectMesh(DbObject obj, MeshFaceterData parameter). Does in the Inventor Api a similiar function exist?
In the parameters I need to set the deviation in the same way as in the Autocad .Net Api.
Example:
FaceterDevNormal = 0.1;
FaceterDevSurface = 0.1;
FaceterMeshType = 2;
Thanks for further help.
Markus
Hi Markus,
There isn't a way to set the deviation similarly than in AutoCAD, but you need to use the "CalculateFacets" API where you can specify a tolerance. Below is a VBA sample, it can be used on SurfaceBody or Face objects, client graphics are used to visualize the result:
Public Sub GenerateFacets(facetable As Variant)
Dim tolerance As Double
Dim VertexCount As Long
Dim FacetCount As Long
Dim VertexCoords() As Double
Dim normals() As Double
Dim Indices() As Long
tolerance = 0.003
Call facetable.CalculateFacets(tolerance, VertexCount, FacetCount, VertexCoords, normals, Indices)
Dim nbTriangles As Long
nbTriangles = 0
Dim i As Integer
For i = 0 To UBound(Indices) Step 3
Dim vIndex1 As Integer
Dim vIndex2 As Integer
Dim vIndex3 As Integer
vIndex1 = (Indices(i) - 1) * 3
vIndex2 = (Indices(i + 1) - 1) * 3
vIndex3 = (Indices(i + 2) - 1) * 3
Dim vertex1(2) As Double
Dim vertex2(2) As Double
Dim vertex3(2) As Double
vertex1(0) = VertexCoords(vIndex1)
vertex1(1) = VertexCoords(vIndex1 + 1)
vertex1(2) = VertexCoords(vIndex1 + 2)
vertex2(0) = VertexCoords(vIndex2)
vertex2(1) = VertexCoords(vIndex2 + 1)
vertex2(2) = VertexCoords(vIndex2 + 2)
vertex3(0) = VertexCoords(vIndex3)
vertex3(1) = VertexCoords(vIndex3 + 1)
vertex3(2) = VertexCoords(vIndex3 + 2)
'Call custom method to visualize facet edges
Call DrawLineGraphics(vertex1, vertex2)
Call DrawLineGraphics(vertex2, vertex3)
Call DrawLineGraphics(vertex3, vertex1)
nbTriangles = nbTriangles + 1
Next
ThisApplication.ActiveView.Update
End Sub
Public Sub DrawLineGraphics(startpt() As Double, endpt() As Double)
Dim doc As Document
Set doc = ThisApplication.ActiveDocument
Dim compDef As ComponentDefinition
Set compDef = doc.ComponentDefinition
On Error Resume Next
Dim dataSets As GraphicsDataSets
Set dataSets = doc.GraphicsDataSetsCollection("LineGraphics")
Dim clientGraphics As clientGraphics
Set clientGraphics = compDef.ClientGraphicsCollection("LineGraphics")
If Err Then
Err.clear
Set dataSets = doc.GraphicsDataSetsCollection.Add("LineGraphics")
Set clientGraphics = compDef.ClientGraphicsCollection.Add("LineGraphics")
Call dataSets.CreateCoordinateSet(1)
Call clientGraphics.AddNode(1)
Call clientGraphics(1).AddLineGraphics
End If
On Error GoTo 0
Dim coordSet As GraphicsCoordinateSet
Set coordSet = dataSets(1)
Dim coords() As Double
Call coordSet.GetCoordinates(coords)
Dim idx As Long
idx = 3 * coordSet.count
ReDim Preserve coords(0 To idx + 5)
coords(idx) = startpt(0)
coords(idx + 1) = startpt(1)
coords(idx + 2) = startpt(2)
coords(idx + 3) = endpt(0)
coords(idx + 4) = endpt(1)
coords(idx + 5) = endpt(2)
Call coordSet.PutCoordinates(coords)
Dim lineGraphics As lineGraphics
Set lineGraphics = clientGraphics(1).item(1)
lineGraphics.CoordinateSet = coordSet
End Sub
Philippe.
