I think this has been asked before but I haven't found a total solution.
When I make a drawing, often times page 1 will be the entire assembly and in subsequent pages (sheets), I will dimension each individual component, etc. In the "Name" field in my title block, I have it grabbing the "Title" and "Subject" iProperties. Just so happens, those fields are ALWAYS the same for each part as it is for the assembly.
What is the best way I can either
A) AUTOMATICALLY copy the "Title" and "Subject" iProperty fields from the assembly to EACH part that makes it up
or even BETTER
B) AUTOMATICALLY copy the "Title" and "Subject" information from sheet 1 to the same place on all subsequent sheets
Or BEST
C) Have the title block template pull that data from the assembly, EVEN IF only a singloe part is on the sheet.
The best I have so far is below, but it's not quite doing what I want. WHere it says "Sheet1"...I don't know how to actually pick sheet 1 (I don't want the active sheet, I always want sheet 1)
I like what this is doing...creating a custom property called "Name Param" from the "Title" property of the main assembly. I'd rather do it this way than actually copy the assembly property to each part property.
Any help?
iProperties.Value("Custom", "Name Param") = String.Empty oRefDoc = Sheet1.View("VIEW1").ModelDocument iProperties.Value("Custom", "Name Param") = iProperties.ValueInDoc(oRefDoc, "Project", "Title")
Hi There,
You can access the first sheet in a drawing using DrawingDocument.Sheets(1). You can then set a field in the title block to display a specific iProperty value.
Let me know if that answers your question or you need further help.
Philippe.
