Can I copy and past an assembley file to another folder in my system,as like as packandgo using inventor api ?can anyone help?
if you are using Invenor 2014, you could use the new API
http://adndevblog.typepad.com/manufacturing/2013/05/use-packandgo-of-2014-api.html
with the previous releases, please refer to the SDK sample
C:\Users\Public\Documents\Autodesk\Inventor 201*\SDK\UserTools\CopyDesign
Hi...Thanks.. But when I using inventor 2014 there will be an error.
the error says
Retrieving the COM class factory for component with CLSID {F2D4F4E5-EEA1-46FF-A83B-A270C92DAE4B} failed due to the following error: 80040154 Class not registered (Exception from HRESULT: 0x80040154 (REGDB_E_CLASSNOTREG)).
anyone help what is this error?
