I believe you need to set the value of the registry entry to 2 for what you
want.
If "MaintainRelativeDimTextPosition" = 0, Dim text maintains its position
relative to view
If "MaintainRelativeDimTextPosition" = 1, Dim text maintains its position
relative to view or maintain centered (if the dim text is centered)
If "MaintainRelativeDimTextPosition" = 2, Dim text maintains its position
relative to the dimension line (Percentage)
This is for Inventor 9 only and you will need to restart Inventor to for the
registry entry to take effect.
Sanjay-
wrote in message news:4889095@discussion.autodesk.com...
hi Sanjay,
Thank you for your reply. I set the MaintainRelativeDimTextPosition
registry key to 1 and then I updated my part from small size to larger size.
All dimensions that I placed on my template drawing for this part is no
longer in neatly positioned. I tried to change couple registry keys in same
DrawingFormat like DrawingSheetPrefix key to something different than
"Sheet" and I didn't notice any differences.
Thank you,
NewVBA
