I am doing a customization in inventor 2012 using vb.net as development language.
I am opening and closing the documents in background, in this process some of documents are left open and not closed as the result draughtsman is not able to change the project. Even though active document is closed inventor show few documents in extreme right bottom corner.
My problem is am tring to figure out how to close these active documents. I am trying to find out Active Document closing event if any.
Requesting to provide a idea to this problem on how i can close those documents which i opened using API in single shot
Cheers,
Amit
Solved by santoshr0114. Go to Solution.
Hi Amit,
Below three steps might help you out.
You can use Documents.CloseAll to close all in a single shot.
What operations are performed by the documents which are opened using API also matters....
Hi Santosh,
Thanks for reply.
I used the Documents.CloseAll to close all open documents in a single shot by creating a new button
Cheers,
Amit
Hi amitk
i have the similar problem but i not have idea how to resolve, you may shared your code or your solution....please?
thank you!
Hola amitk
tengo el mismo problema pero yo no tengo idea de cómo resolver, usted puede compartir su código o su solución .... por favor?
Gracias!
