Inventor Programming - iLogic, Macros, AddIns & Apprentice
Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
Client graphics
4 REPLIES 4
DWhiteley
325 Views, 4 Replies
Client graphics
Is there now a way of taking an assembly and creating a custom graphics copy of the assembly to surfacegraphics AND keep the original colors of the parts in the assembly? In other words the assembly and the resultant customgraphics would look the same.
Some releases ago, you could only re-color the complete surfacegraphics body as one color.
Thanks, Dave
4 REPLIES 4
Hi Dave,
You can do that by creating a ComponentGraphics. It takes directly the ComponentDefinition of a part or assembly and will conserve the original colors.
Now if you really want to have a SurfaceGraphics there is no direct way to do it: the render style is affected at the GraphicsNode level, so you would need to create one node per render style, affect different style for each node and create as many SurfaceGraphics has needed.
I hope it helps,
Philippe.
Philippe Leefsma
Developer Technical Services
Autodesk Developer Network
DWhiteley
in reply to: DWhiteley
Thanks Phillipe,
So if I use componentgraphics, can I then slice like I can with
surfacegraphics?
Regards
Dave
Dave Whiteley
Technical Director
Tel 01656 662414
Fax 01656 662415
E-mail dave@envisageuk.com
Webwww.envisageuk.com
Description: Description: Description:cid:image001.jpg@01CE39DB.28DC4B70Description: Description: Description:
cid:image002.jpg@01CE39DB.28DC4B70
Description: Description: Description:Description: Description: Description: Description: Description:
Description: http://www.envisageuk.com/images/blogspotlogo.jpg
aq=f&aqi=&aql=&gs_l=youtube.3...53014.55175.0.55331.13.12.0.1.1.0.79.818.12.
12.0...0.0.TEN-Z0WbvI0> Description: Description: Description: Description:
Description: Description: Description: cid:image002.jpg@01CD34DE.99949CD0
cid:image002.png@01CD1C96.A4B219E0
Description: cid:image004.jpg@01CD34E9.BDA7AF80
Envisage UK Limited, Avon Court, Cowbridge Road, Bridgend, Mid Glamorgan,
CF31 3SR
Company Registration: 2962716
P Save a tree...please don't print this e-mail unless you really need to
This e-mail transmission is intended only for the use of the individual or
entity named above and may contain information that is confidential,
privileged, and exempt from disclosure under applicable law.
If you are not the intended recipient, you are hereby notified that any
disclosure, copying, distribution, or use of any of the information
contained in this transmission is strictly PROHIBITED.
If you have received this transmission in error, please immediately notify
me by e-mail at the above address. Thank you.
This email is free from viruses and malware because avast! Antivirus protection is active.
http://www.avast.com
Yes, SliceGraphics applies to the GraphicsNode, you can slice any graphics that belongs to that node.
Philippe.
Philippe Leefsma
DWhiteley
Brilliant, thanks Phillipe.
Regards
Dave
Dave Whiteley
Technical Director
Tel 01656 662414
Fax 01656 662415
CF31 3SR
