Inventor Customization
Valued Contributor
jonbrabbs
Message 1 of 2 (331 Views)
Class Not Registered Error
331 Views, 1 Replies
10-08-2012 02:20 AM
Morning All,
I'm banging my head against a wall with this one. Until recently, my program was working fine, both in dev world (VB.NET 2008 EE), and as a standalone app. Then something changed, although I'm not sure what - it was either something I did unknowingly, or a round of system updates which run overnight. Can't be sure which - I've done a fair bit of fettling on my program!
The program opens Inventor 2010, and various part/drawing files, in the background and creates a dwf of the drawing and model. This should then be shown in my app using the dwfViewer addin. The addin shows up fine in the designer, but when I come to run the app, I get a class not registered error (see attached file).
I've tried registereing just about everything I can think of, although it's fair to say I haven't really gto much idea what I should be doing here.
Design Review (2010) works fine itself (i reinstalled it, just to make sure) and has no problems, it's just the dwfviewer that I'm struggling with.
Any and all help would be greatly appreciated. I have't got much hair left to pull out...
Kind regards
Jon.
If this post helps you, please give kudos.
Valued Contributor
jonbrabbs
Message 2 of 2 (324 Views)
Re: Class Not Registered Error
10-08-2012 03:15 AM in reply to: jonbrabbs
Ok, fixed it. I still don't know what happened or why, but after 3 days of head scratching I found the fault and the cure.
In the .vbproj file, I was missing the following code
<PlatformTarget>x86</PlatformTarget> - I added it directly under the first <PropertyGroup> and iit is now working again.
I don't know why my app was working and then stopped, but at least I won't lose any more hair/sleep over this.
I'm going to put it down to a "Windows Issue".
Problem Solved.
Jon.
You are not logged in.
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
