Can anybody help?
I need to know what sketch is associated to either a "Rectangular"or "Circular"array.
This is so I can filter out sketches that are not repeated in an array.
Here is my code so far (Circular Array).
Dim oCP As CircularPatternFeature
For Each oCP In oDef.Features.CircularPatternFeatures
THIS IS THE TROUBLE LINE If sketch = oCP.Parent Then
Set oCP = oDef.Features.CircularPatternFeatures.Item(oCP.Name)
Set oPar = oCP.Count
Xcount = oPar.Value
Set oPar = oCP.Angle
FitAngle = oPar.Value * Rad
If FitAngle = 360 Then
IncrementalAngle = 360 / Xcount
Else
IncrementalAngle = FitAngle / (Xcount - 1)
End If
For Counter = 1 To Xcount
Set oFPE = oCP.PatternElements.Item(Counter)
If oFPE.Suppressed = False Then
AbsoluteAngle = (Counter - 1) * IncrementalAngle
REM Call CircularArray
End If
Next Counter
End If
Next
I have a simple test part containing an extruded disk (Sketch1) and 8 holes on a pcd (Sketch2). I only want to array a sketch if it is arrayed,
Many thanks in advance!!!
IsoCAM
Solved by Vladimir.Ananyev. Go to Solution.
Hi isocam,
I would say that the Circular Array is the Parent of the Sketch. The way you have it written I believe you're asking if the sketch is the Parent of the Circular Array.
Regards
Mitch
Let me know if it helps... Kudos if it works!!!
Mitch,
Can you please give me a working example of the line of code I need to achieve this?
I cannot seem to get the correct code to do this!
Many thanks!!!!!
IsoCAM
Hi Isocam,
May I ask what exactly you are trying to do with the code? That way I have an idea when trying to fix it.
Regards
Mitch
Hi Isocam,
if you need a reference to the planar sketch where arrayed
geometry was sketched then look to these code samples:
Sub TEST_Rect() Dim oDoc As PartDocument Set oDoc = ThisApplication.ActiveDocument Dim oDef As PartComponentDefinition Set oDef = oDoc.ComponentDefinition 'reference to rect. pattern Dim oRP As RectangularPatternFeature Set oRP = oDef.Features.RectangularPatternFeatures _ .Item("Rectangular Pattern1") Dim oParentFeature As ExtrudeFeature 'one of PartFeature Set oParentFeature = oRP.ParentFeatures.Item(1) Dim oSketch As PlanarSketch Set oSketch = oParentFeature.Profile.Parent Debug.Print "Parent sketch: " & oSketch.Name End Sub Sub TEST_Circ() Dim oDoc As PartDocument Set oDoc = ThisApplication.ActiveDocument Dim oDef As PartComponentDefinition Set oDef = oDoc.ComponentDefinition 'reference to circ. pattern Dim oCP As CircularPatternFeature Set oCP = oDef.Features.CircularPatternFeatures _ .Item("Circular Pattern1") Dim oParentFeature As ExtrudeFeature 'one of PartFeature Set oParentFeature = oCP.ParentFeatures.Item(1) Dim oSketch As PlanarSketch Set oSketch = oParentFeature.Profile.Parent Debug.Print "Parent sketch: " & oSketch.Name End Sub
In both cases it is assumed that patterns were created using ExtrudeFeature objects.
