Inventor Programming - iLogic, Macros, AddIns & Apprentice
Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
Check part parameter within assembly
1 REPLY 1
383 Views, 1 Reply
I'm trying to run a for loop to check a part's thickness parameter within an assembly but I do not know how to access that parameter from the assembly. Once I check that the thickness does not equal 1/4" I want to assign the sheet metal rule to be user defined. Here is what I got so far:
Dim SheetMetalRule As String = BODY_GAUGE & " " & SHEET_METAL_RULE
Dim assyDoc As AssemblyDocument
assyDoc = ThisApplication.ActiveDocument
Dim partDoc As Document
For Each partDoc In assyDoc.AllReferencedDocuments
If partDoc.ComponentDefinition.Parameters.UserParameters("THICK").Value = .25 Then
Else If partDoc.ComponentDefinition.Parameters.UserParams.Value <> .25 Then
ThisApplication.Documents.Open(partDoc.FullFileName, False)
SheetMetal.SetActiveStyle(SheetMetalRule)
partDoc.Save
partDoc.Close
Next
1 REPLY 1
adam.nagy
The sheet metal thickness parameter seems to be called "Thickness", so this should work.
Also keep in mind that internally length values are in cm. So you would need to convert it - you could also use UnitsOfMeasure class for that.
doc = ThisDoc.Document
MsgBox(doc.ComponentDefinition.Parameters("Thickness").Value)
I hope this helps.
Cheers,
Adam Nagy
Autodesk Platform Services
