Nacho
Automation & Design Engineer
Inventor Programmer (C#, VB.Net / iLogic)
Nacho
I also really need the solution to this problem.
How can I reset the original z,y,z, coordinates of th epart, to match the new front face which I have changed by right-clicking the view cube and selecting 'select current view as front'?
Thanks in advance
Hi
i dont thinks possible. every feature like 'extrude' etc creates co-ordinates x,y & z. if the true orientation was changed, it might mess up the part co-ordinates. I found a solution for my use (always bringing the correct orientation onto a drawing sheet)
The solution was in the Styles. Open the styles editor and select as the image
NOTE:
Your standard may not be called 'Sloane' as mine. It wants to the standard that you are using
You need to change the Front View Plane to the setting 'From Model'
Cheers
Nigel
Nacho
