please be somewhere in Inventor to override the default size when creating holes?
I need to change the size of 3 mm to 4.2 mm.
Thank you very much for your answer,
Daniel Zdeněk
Everytime i make a hole the first time in a part the hole is ø 3mm WHY !?
I know that when i made a hole the next hole will be the same as the previously BUT if I restart the model I am back to ø3 mm again
There must be somewhere I can change this value somewhere in the registry. I do 98% of my holes 4,2 mm this is really anoying !
