How to select entity filter by sketch name dan propeties using VB or VBA.
for example I have 2 shape : Rectangular and Circle with diffrent propeties.
Sometimes I want to select rec and make it become construction and circle still in normal line andSometimes I want to select cicle and make it become construction and rectangular still in normal line.
Abi Labib
Before you start InteractionEvents and SelectEvents, you can specify the SelectionFilter, by SelectEvents.AddSelectionFilter. The enum SelectionFilterEnum provides
kSketchCurveLinearFilter
kSketchCurveCircularFilter
In the API help document, a tutorial introduces how to implement InteractionEvents step by step. The attached snapshot indicates where the topic is. And the API help reference locates at <Inventor Installation path>\help_lite\admapi_16_0.chm. 16 means Inventor 2012.
